Sound Signals Decomposition Using a High Resolution Matching Pursuit - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1996
Sound recordings include transients and sustained parts. Their analysis with a basis expansion is not rich enough to represent efficiently all such components. Pursuit algorithms choose the decomposition vectors depending upon the signal properties. The dictionary among which these vectors are selected is much larger than a basis. Matching Pursuit is fast to compute, but can provide coarse representations. Basis Pursuit gives a better representation but is very expensive in terms of calculation time. This paper develops a High Resolution Matching Pursuit : it is a fast, high time-resolution, time-frequency anal;ysis algorithm, that makes it likely to be used for musical applications.
Fichier non déposé
inria-00576655 , version 1 (15-03-2011)
  • HAL Id : inria-00576655 , version 1
Rémi Gribonval, Philippe Depalle, Xavier Rodet, Emmanuel Bacry, Stéphane Mallat. Sound Signals Decomposition Using a High Resolution Matching Pursuit. Proc. Int. Computer Music Conf. (ICMC'96), Aug 1996, Hong-Kong, Hong Kong SAR China. pp.293-296. ⟨inria-00576655⟩
83 Consultations
0 Téléchargements
