Optimistic access control for distributed collaborative editors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The importance of collaborative systems in real-world applications has grown significantly over the recent years. The majority of new applications are designed in a distributed fashion to meet collaborative work requirements. Among these applications, we focus on Distributed Collaborative Editors (DCE) that provide computer support for modifying simultaneously shared documents, such as articles, wiki pages and programming source code by dispersed users. Although such applications are more and more used into many fields, the lack of an adequate access control concept is still limiting their full potential. In fact, controlling access in a decentralized fashion for such systems is still a challenging problem, as they need dynamic access changes and low latency access to shared documents. In this paper, we propose a generic Multi-Administrator Access Control (MAAC) based on replicating the shared document and its authorization policy at the local memory of each user. We consider the propagation of authorizations and their interactions. We propose a generic approach to enforce access control in existing collaborative editing solutions. Finally, we apply our framework on a collaboration prototype and measure its performance in the distributed grid GRID5000 to highlight the scalability of our solution
Fichier non déposé
inria-00576880 , version 1 (15-03-2011)
Asma Cherif, Abdessamad Imine, Michaël Rusinowitch. Optimistic access control for distributed collaborative editors. 2011 ACM Symposium on Applied Computing (SAC), Mar 2011, Taichung, Taiwan. pp.861-868, ⟨10.1145/1982185.1982374⟩. ⟨inria-00576880⟩
171 Consultations
0 Téléchargements
