Fuel-Optimal Trajectories for Continuous-Thrust Orbital Rendezvous with Path Constraints
Outline 1 Problem statement -Dynamical equations -Optimal control formulation 2 Solving the path-constrained rendezvous problem -Smoothing the bang-o-bang control -A new approach to deal with the state constraint 3 Numerical results - A rendezvous in Highly Elliptical Orbit -Statement of the test case -Unconstrained rendezvous -Rendezvous under collision avoidance constraint 4 Conclusion and future prospects
Optimisation et contrôle [math.OC]
