Closed-Form MMSE Estimation for Signal Denoising Under Sparse Representation Modeling Over a Unitary Dictionary - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Signal Processing Année : 2010
This paper deals with the Bayesian signal denoising problem, assuming a prior based on a sparse representation modeling over a unitary dictionary. It is well known that the maximum a posteriori probability (MAP) estimator in such a case has a closed-form solution based on a simple shrinkage. The focus in this paper is on the better performing and less familiar minimum-mean-squared-error (MMSE) estimator. We show that this estimator also leads to a simple formula, in the form of a plain recursive expression for evaluating the contribution of every atom in the solution. An extension of the model to real-world signals is also offered, considering heteroscedastic nonzero entries in the representation, and allowing varying probabilities for the chosen atoms and the overall cardinality of the sparse representation. The MAP and MMSE estimators are redeveloped for this extended model, again resulting in closed-form simple algorithms. Finally, the superiority of the MMSE estimator is demonstrated both on synthetically generated signals and on real-world signals (image patches).
Fichier non déposé
inria-00577220 , version 1 (16-03-2011)
Matan Protter, Irad Yavneh, Michael Elad. Closed-Form MMSE Estimation for Signal Denoising Under Sparse Representation Modeling Over a Unitary Dictionary. IEEE Transactions on Signal Processing, 2010, 58 (7), pp.3471 -3484. ⟨10.1109/TSP.2010.2046596⟩. ⟨inria-00577220⟩
111 Consultations
0 Téléchargements
