Second-order analysis of optimal control problems with control and initial-final state constraints, Journal of Convex Analysis, vol.17, issue.3, pp.885-913, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00335869
Problems for extremum under constraints, Zh. Vychislit. Mat. i Mat. Fiz. English transl. in U.S.S.R. Comput. Math. and Math. Phys, vol.5, issue.5, pp.395-453, 1965. ,
Higher-order local minimum conditions in problems with constraints, Uspekhi Mat. Nauk, Russian Math. Surveys, vol.33, issue.33 6, pp.85-148, 1978. ,
Maximum Principle in the General Optimal Control Problem, 2001. ,
Calculus of Variations and Optimal Control, Translations of Mathematical Monographs, vol.180, 1998. ,
Quadratic optimality conditions for broken extremals in the general problem of calculus of variations, Journal of Math. Science, vol.123, pp.3-3987, 2004. ,
Second-order sufficient optimality conditions for control problems with linearly independent gradients of control constraints, COCV ,
Sufficient quadratic conditions of extremum for discontinuous controls in optimal control problems with mixed constraints, Journal of Mathematical Sciences, vol.32, issue.5, pp.1-106, 2011. ,
DOI : 10.1007/s10958-011-0233-x
