A penalization method to take into account obstacles in incompressible viscous flows, Numerische Mathematik, vol.81, issue.4, pp.497-520, 1999. ,
DOI : 10.1007/s002110050401
Sur les conditions hydrodynamiques au voisinage d'une interface milieu fluide-milieux poreux: application la convection naturelle, C.R. Acad. Sci. Paris II, vol.299, pp.1-4, 1984. ,
Die Methode der finiten Elemente f??r elliptische Gleichungen mit diskontinuierlichen Koeffizienten, Computing, vol.19, issue.3, pp.207-213, 1970. ,
DOI : 10.1007/BF02248021
PETSc users manual, 2008. ,
Efficient Management of Parallelism in Object-Oriented Numerical Software Libraries, Modern Software Tools in Scientific Computing, pp.163-202, 1997. ,
DOI : 10.1007/978-1-4612-1986-6_8
A decomposed immersed interface method for variable coefficient elliptic equations with non-smooth and discontinuous solutions, Journal of Computational Physics, vol.197, issue.1, pp.364-386, 2004. ,
DOI : 10.1016/j.jcp.2003.12.003
A finite element method for interface problems in domains with smooth boundaries and interfaces, Advances in Computational Mathematics, vol.58, issue.1, pp.109-138, 1996. ,
DOI : 10.1007/BF02127700
Computational Modeling of Solid Tumor Growth: The Avascular Stage, SIAM Journal on Scientific Computing, vol.32, issue.4, 2009. ,
DOI : 10.1137/070708895
URL : https://hal.archives-ouvertes.fr/inria-00148610
Numerical studies on the effect of electric pulses on an egg-shaped cell with a spherical nucleus, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00477495
Level-set, penalization and cartesian meshes: A paradigm for inverse problems and optimal design, Journal of Computational Physics, vol.228, issue.17, pp.6291-6315, 2009. ,
DOI : 10.1016/j.jcp.2009.05.017
URL : https://hal.archives-ouvertes.fr/hal-00385460
Finite element methods and their convergence for elliptic and parabolic interface problems, Numerische Mathematik, vol.79, issue.2, pp.175-202, 1998. ,
DOI : 10.1007/s002110050336
A coupling interface method for elliptic interface problems, Journal of Computational Physics, vol.225, issue.2, pp.2138-2174, 2007. ,
DOI : 10.1016/j.jcp.2007.03.012
The immersed finite volume element methods for the elliptic interface problems, Mathematics and Computers in Simulation, vol.50, issue.1-4, pp.63-76, 1999. ,
DOI : 10.1016/S0378-4754(99)00061-0
Coupling an Eulerian Fluid Calculation to a Lagrangian Solid Calculation with the Ghost Fluid Method, Journal of Computational Physics, vol.175, issue.1, pp.200-224, 2002. ,
DOI : 10.1006/jcph.2001.6935
A Non-oscillatory Eulerian Approach to Interfaces in Multimaterial Flows (the Ghost Fluid Method), Journal of Computational Physics, vol.152, issue.2 ,
DOI : 10.1006/jcph.1999.6236
A Second-Order-Accurate Symmetric Discretization of the Poisson Equation on Irregular Domains, Journal of Computational Physics, vol.176, issue.1, pp.205-227, 2002. ,
DOI : 10.1006/jcph.2001.6977
A fourth order accurate discretization for the Laplace and heat equations on arbitrary domains, with applications to the Stefan problem, Journal of Computational Physics, vol.202, issue.2, pp.577-601, 2005. ,
DOI : 10.1016/j.jcp.2004.07.018
A fourth order accurate discretization for the laplace and heat equations on arbitrary domains, with applications to the stefan problem, SIAM Journal of Numerical Analysis, vol.39, pp.396-406, 1975. ,
The Convergence Rate for Difference Approximations to General Mixed Initial-Boundary Value Problems, SIAM Journal on Numerical Analysis, vol.18, issue.2, pp.179-190, 1981. ,
DOI : 10.1137/0718014
A mortar element method for elliptic problems with discontinuous coefficients. A mortar element method for elliptic problems with discontinuous coefficients, pp.549-576, 2002. ,
Exact subgrid interface correction schemes for elliptic interface problems, Proceedings of the National Academy of Sciences of the United States of America, p.9874, 2008. ,
DOI : 10.1073/pnas.0707997105
A Cartesian Grid Embedded Boundary Method for Poisson's Equation on Irregular Domains, Journal of Computational Physics, vol.147, issue.1, pp.60-85, 1998. ,
DOI : 10.1006/jcph.1998.5965
The Immersed Interface Method for Elliptic Equations with Discontinuous Coefficients and Singular Sources, SIAM Journal on Numerical Analysis, vol.31, issue.4, pp.1019-1044, 1994. ,
DOI : 10.1137/0731054
A Fast Iterative Algorithm for Elliptic Interface Problems, SIAM Journal on Numerical Analysis, vol.35, issue.1, pp.230-254, 1998. ,
DOI : 10.1137/S0036142995291329
Maximum Principle Preserving Schemes for Interface Problems with Discontinuous Coefficients, SIAM Journal on Scientific Computing, vol.23, issue.1, pp.339-361, 2001. ,
DOI : 10.1137/S1064827500370160
A Boundary Condition Capturing Method for Poisson's Equation on Irregular Domains, Journal of Computational Physics, vol.160, issue.1, pp.151-178, 2000. ,
DOI : 10.1006/jcph.2000.6444
A fat boundary method for the poisson problem in a domain with holes, Journal of Scientific Computing, vol.16, issue.3, pp.319-339, 2001. ,
DOI : 10.1023/A:1012821728631
The Fast Solution of Poisson???s and the Biharmonic Equations on Irregular Regions, SIAM Journal on Numerical Analysis, vol.21, issue.2, pp.285-299, 1984. ,
DOI : 10.1137/0721021
The rapid evaluation of volume integrals of potential theory on general regions, Journal of Computational Physics, vol.100, issue.2, pp.236-245, 1992. ,
DOI : 10.1016/0021-9991(92)90231-M
Fast Parallel Iterative Solution of Poisson???s and the Biharmonic Equations on Irregular Regions, SIAM Journal on Scientific and Statistical Computing, vol.13, issue.1, pp.101-118, 1992. ,
DOI : 10.1137/0913006
A Cartesian Grid Embedded Boundary Method for the Heat Equation on Irregular Domains, Journal of Computational Physics, vol.173, issue.2, pp.620-635, 2001. ,
DOI : 10.1006/jcph.2001.6900
A sharp interface finite volume method for elliptic equations on Cartesian grids, Journal of Computational Physics, vol.228, issue.14, pp.5184-5206, 2009. ,
DOI : 10.1016/j.jcp.2009.04.018
Level Set Methods and Dynamic Implicit Surfaces, 2003. ,
DOI : 10.1115/1.1760520
URL : http://dx.doi.org/10.1016/s0898-1221(03)90179-9
Fronts propagating with curvature-dependent speed: Algorithms based on Hamilton-Jacobi formulations, Journal of Computational Physics, vol.79, issue.1, p.79, 1988. ,
DOI : 10.1016/0021-9991(88)90002-2
Sparskit a basic tool-kit for sparse matrix computations ,
The algebraic immersed interface and boundary method for elliptic equations with discontinuous coefficients, 2009. ,
Level Set Methods and Fast Marching Methods, 1999. ,
Evolution, Implementation, and Application of Level Set and Fast Marching Methods for Advancing Fronts, Journal of Computational Physics, vol.169, issue.2, pp.503-555, 2001. ,
DOI : 10.1006/jcph.2000.6657
On the order of accuracy for difference approximations of initial-boundary value problems, Journal of Computational Physics, vol.218, issue.1, pp.333-352, 2006. ,
DOI : 10.1016/j.jcp.2006.02.014
The Explicit-Jump Immersed Interface Method: Finite Difference Methods for PDEs with Piecewise Smooth Solutions, SIAM Journal on Numerical Analysis, vol.37, issue.3, pp.827-862, 2000. ,
DOI : 10.1137/S0036142997328664
Three-dimensional matched interface and boundary (MIB) method for treating geometric singularities, Journal of Computational Physics, vol.227, issue.1, pp.602-632, 2007. ,
DOI : 10.1016/j.jcp.2007.08.003
A new high-order immersed interface method for solving elliptic equations with imbedded interface of discontinuity, Journal of Computational Physics, vol.225, issue.1, pp.1066-1099, 2007. ,
DOI : 10.1016/j.jcp.2007.01.017
On the fictitious-domain and interpolation formulations of the matched interface and boundary (MIB) method, Journal of Computational Physics, vol.219, issue.1, pp.228-246, 2006. ,
DOI : 10.1016/j.jcp.2006.03.027
High order matched interface and boundary method for elliptic equations with discontinuous coefficients and singular sources, Journal of Computational Physics, vol.213, issue.1, pp.1-30, 2006. ,
DOI : 10.1016/j.jcp.2005.07.022
Europe -38334 Montbonnot Saint-Ismier Centre de recherche INRIA Lille ? Nord Europe : Parc Scientifique de la Haute Borne -40, avenue Halley -59650 Villeneuve d'Ascq Centre de recherche INRIA Nancy ? Grand Est : LORIA, Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 Villers-lès-Nancy Cedex Centre de recherche INRIA Paris ? Rocquencourt : Domaine de Voluceau -Rocquencourt -BP 105 -78153 Le Chesnay Cedex Centre de recherche INRIA Rennes ? Bretagne Atlantique : IRISA, Campus universitaire de Beaulieu -35042 Rennes Cedex Centre de recherche INRIA Saclay ? Île-de-France, des Vignes : 4, rue Jacques Monod -91893 Orsay Cedex Centre de recherche INRIA, pp.105-78153, 2004. ,
