New interface
Journal articles
On the marginal instability of linear switched systems
Yacine Chitour 1 Paolo Mason 1 Mario Sigalotti 2, 3
3 CORIDA - Robust control of infinite dimensional systems and applications
IECN - Institut Élie Cartan de Nancy, LMAM - Laboratoire de Mathématiques et Applications de Metz, Inria Nancy - Grand Est
Abstract : Stability properties for continuous-time linear switched systems are at first determined by the (largest) Lyapunov exponent associated with the system, which is the analogous of the joint spectral radius for the discrete-time case. The purpose of this paper is to provide a characterization of marginally unstable systems, i.e., systems for which the Lyapunov exponent is equal to zero and there exists an unbounded trajectory, and to analyze the asymptotic behavior of their trajectories. Our main contribution consists in pointing out a resonance phenomenon associated with marginal instability. In the course of our study, we derive an upper bound of the state at time $t$, which is polynomial in $t$ and whose degree is computed from the resonance structure of the system. We also derive analogous results for discrete-time linear switched systems.
Complete list of metadata
Cited literature [16 references]  Display  Hide  Download
https://hal.inria.fr/inria-00578133
Contributor : Mario Sigalotti Connect in order to contact the contributor
Submitted on : Monday, May 23, 2011 - 11:02:17 AM
Last modification on : Sunday, June 26, 2022 - 11:53:52 AM
Long-term archiving on: : Wednesday, August 24, 2011 - 2:23:47 AM
File
marginal-revised.pdf
Identifiers
  • HAL Id : inria-00578133, version 4
Citation
Yacine Chitour, Paolo Mason, Mario Sigalotti. On the marginal instability of linear switched systems. Systems and Control Letters, 2012, 61, pp.247-257. ⟨inria-00578133v4⟩
Share
Metrics
Record views
276
Files downloads
317
