Estimating the conditional tail index by integrating a kernel conditional quantile estimator - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Statistical Planning and Inference Année : 2012
This paper deals with the estimation of an extreme value index of a heavy-tailed distribution in the presence of covariates. A class of estimators is proposed in this context and its asymptotic normality established under mild regularity conditions. These estimators are functions of a kernel conditional quantile estimator depending on some tuning parameters. The finite sample properties of our estimators are illustrated on a small simulation study.
kernelgam.pdf (170.94 Ko) Télécharger le fichier
inria-00578479 , version 1 (21-03-2011)
Laurent Gardes, Armelle Guillou, Antoine Schorgen. Estimating the conditional tail index by integrating a kernel conditional quantile estimator. Journal of Statistical Planning and Inference, 2012, 142 (6), pp.1586-1598. ⟨10.1016/j.jspi.2012.01.011⟩. ⟨inria-00578479⟩
182 Consultations
240 Téléchargements
