Abstract : Owing to the rapid emergence and growth of techniques in the engineering application of fractals, it has become necessary to gather the most recent advances on a regular basis. This book is a continuation of the first volume - published in 1997 - but contains interesting developments. A major point is that mathematics has become more and more involved in the definition and use of fractal models. It seems that the time of the qualitative observation of fractal phenomena has gone. Now the main models are strongly based upon theoretical arguments. "Fractals: Theory and Applications in Engineering" is a multidisciplinary book which should interest every scientist working in areas connected with fractals
F. M. Dekking, Jacques Lévy Véhel, Evelyne Lutton, Claude Tricot. Fractals: Theory and Applications in Engineering. Michel Dekking, Jacques Levy Vehel, Evelyne Lutton and Claude Tricot. Springer-Verlag, pp.355, 1999. ⟨inria-00578659⟩
