Distributed memoryless point convergence algorithms for mobile robots with limited visibility, IEEE Transactions on Robotics and Automation, vol.15, issue.5, pp.818-828, 1999. ,
Pattern formation and periodic structures in systems modeled by reaction-diffusion equations, Bulletin of the AMS, vol.84, issue.6, pp.1296-1327, 1978. ,
Interactive table to study interactions between swarms of robots and active environments ,
VLASSOPOULOS N, FATES N, How fast can Virtual Amoebae aggregate? Analysis for the Optimal Firing Rate in an Instance of the Reaction- Diffusion-Chemotaxis Aggregation Scheme, 2010. ,
