Automated Induction with Constrained Tree Automata - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Adel Bouhoula
  • Fonction : Auteur
  • PersonId : 756484
  • IdRef : 132449021
Florent Jacquemard
We propose a procedure for automated implicit inductive theorem proving for equational specifications made of rewrite rules with conditions and constraints. The constraints are interpreted over constructor terms (representing data values), and may express syntactic equality, disequality, ordering and also membership in a fixed tree language. Constrained equational axioms between constructor terms are supported and can be used in order to specify complex data structures like sets, sorted lists, trees, powerlists... Our procedure is based on tree grammars with constraints, a formalism which can describe exactly the initial model of the given specification (when it is sufficiently complete and terminating). They are used in the inductive proofs first as an induction scheme for the generation of subgoals at induction steps, second for checking validity and redundancy criteria by reduction to an emptiness problem, and third for defining and solving membership constraints. We show that the procedure is sound and refutationally complete. It generalizes former test set induction techniques and yields natural proofs for several non-trivial examples presented in the paper, these examples are difficult (if not impossible) to specify and carry on automatically with other induction procedures.
induction-HAL.pdf (276.64 Ko) Télécharger le fichier
inria-00579004 , version 1 (22-03-2011)
Adel Bouhoula, Florent Jacquemard. Automated Induction with Constrained Tree Automata. 4th International Joint Conference on Automated Reasoning (IJCAR), Aug 2008, Sydney, Australia. pp.539-554, ⟨10.1007/978-3-540-71070-7_44⟩. ⟨inria-00579004⟩
87 Consultations
160 Téléchargements
