Extraction des lignes d'un texte manuscrit Arabe, Vision Interface'99, pp.42-48, 1999. ,
Text Line Segmentation in Handwritten Document Using a Production System, International Workshop on Frontiers in Handwriting Recognition, pp.245-250, 2004. ,
Document Image Analysis for World War II Personal Records, International Workshop on Document Image Analysis for Libraries, pp.336-343, 2004. ,
Handwritten document image segmentation and analysis, Pattern Recogn, Lett, vol.14, issue.1, pp.71-78, 1993. ,
DOI : 10.1016/0167-8655(93)90134-y
DMOS, une méthode générique de reconnaissance de documents : ´ evaluation sur 60 000 formulaires du XIXesì ecle, Actes du Colloque International Francophone sur l' ´ Ecrit et le Document (CIFED'02), 2002. ,
A Model-based Line Detection Algorithm in Documents, Proceedings of the Seventh International Conference on Document Analysis and Recognition (ICDAR), p.pp, 2003. ,
Text Line Segmentation in Handwritten Document Using a Production System, Ninth International Workshop on Frontiers in Handwriting Recognition, p.pp, 2004. ,
DOI : 10.1109/IWFHR.2004.100
ContributionàContribution`Contributionà la segmentation de textes manuscrits anciens, Conférence Internationale Francophone sur l'Ecrit et le Document, p.pp, 2004. ,
Extracting lines on handwritten documents by perceptual grouping, in Advances in Handwiting and drawing: multidisciplinary approach, pp.21-38, 1994. ,
Line detection and segmentation in historical church registers, Proceedings of Sixth International Conference on Document Analysis and Recognition, pp.743-748, 2001. ,
DOI : 10.1109/ICDAR.2001.953888
A Hough based algorithm for extracting text lines in handwritten documents, Proceedings of 3rd International Conference on Document Analysis and Recognition, pp.774-777, 1995. ,
DOI : 10.1109/ICDAR.1995.602017
A NATURAL LEARNING ALGORITHM BASED ON HOUGH TRANSFORM FOR TEXT LINES EXTRACTION IN HANDWRITTEN DOCUMENTS, Proceedings of the 6th International Workshop on Frontiers in Handwriting Recognition, pp.637-646, 1998. ,
DOI : 10.1142/9789812797650_0014
Text line and word segmentation of handwritten documents, Pattern Recognition, vol.42, issue.12, pp.3169-3183, 2009. ,
DOI : 10.1016/j.patcog.2008.12.016
Line Separation for Complex Document Images Using Fuzzy Run length, Int. Workshop on Document Image Analysis for Libraries, 2004. ,
Networking digital document images, 6th International Conference on Document Analysis and Recognition, 2001. ,
Repulsive attractive network for baseline extraction on document images, 1997 IEEE International Conference on Acoustics, Speech, and Signal Processing, pp.1-10, 1999. ,
DOI : 10.1109/ICASSP.1997.595468
Handwritten Chinese text line segmentation by clustering with distance metric learning, Proc. 11th ICFHR, pp.229-234, 2008. ,
DOI : 10.1016/j.patcog.2008.12.013
Effective substances In: The Dictionary of Substances and Their Effects Available via DIALOG, Royal Society of Chemistry, vol.15, 1999. ,
Snakes: Active contour models, Proc. 1st ICCV, 987, pp.259-268 ,
DOI : 10.1007/BF00133570
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.124.5318
STACS: new active contour scheme for cardiac MR image segmentation, IEEE Transactions on Medical Imaging, vol.24, issue.5, pp.593-603, 2005. ,
DOI : 10.1109/TMI.2005.843740
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.154.7270
Geometric Level Set Methods in Imaging,Vision,and Graphics, 2003. ,
Curvature and the evolution of fronts, Communications in Mathematical Physics, vol.40, issue.4, pp.487-499, 1985. ,
DOI : 10.1007/BF01210742
From Splines and Snakes to SNAKE SPLINES, Selected Papers from the Workshop on Geometric Reasoning for Perception and Action, pp.264-281, 1993. ,
A Mumford???Shah level-set approach for the inversion and segmentation of X-ray tomography data, Journal of Computational Physics, vol.221, issue.2, pp.539-557, 2007. ,
DOI : 10.1016/j.jcp.2006.06.041
Segmentation of Curled Textlines using Active Contours, The Eighth IAPR Workshop on Document Analysis Systems, pp.270-277, 2008. ,
Script-Independent Text Line Segmentation in Freestyle Handwritten Documents, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.30, issue.8, pp.1313-1329, 2008. ,
DOI : 10.1109/TPAMI.2007.70792
Optimal approximations by piecewise smooth functions and associated variational problems, Communications on Pure and Applied Mathematics, vol.3, issue.5, pp.577-685, 1989. ,
DOI : 10.1002/cpa.3160420503
URL : http://nrs.harvard.edu/urn-3:HUL.InstRepos:3637121
Text line segmentation in handwritten documents using Mumford???Shah model, Pattern Recognition, vol.42, issue.12, pp.3136-3145, 2009. ,
DOI : 10.1016/j.patcog.2008.12.021
Gradient Vector Flow, Proc. IEEE Conf. on Comp. Vis. Patt. Recog. (CVPR), pp.66-71, 1997. ,
DOI : 10.1007/978-0-387-31439-6_712
A review of deformable surfaces: topology, geometry and deformation, Image and Vision Computing, vol.19, issue.14, pp.1023-1040, 2001. ,
DOI : 10.1016/S0262-8856(01)00064-6
URL : https://hal.archives-ouvertes.fr/inria-00615110
On the Use of the Io-Sinh Window for Spectrum Analysis, IEEE Transactions on Acoustics, Speech and Signal Processing, issue.1, p.28, 1980. ,
Quelques commentaires sur des représentations temps-fréquence proposées récemment, pp.3-25, 1992. ,
Generalized Phase-Space Distribution Functions, Journal of Mathematical Physics, vol.7, issue.5, pp.781-786, 1966. ,
DOI : 10.1063/1.1931206
Sur une formulation générale de la représentation en temps et en fréquence dans l'analyse des signaux d'´ energie finie, CR. Acad. Sci. Paris, vol.283, pp.1049-1051, 1976. ,
The Wigner distribution -A tool for time frequency analysis, Parts I-III, Philips J. Res, vol.35, pp.217-250, 1980. ,
Linear and quadratic time-frequency signal representations, IEEE Signal Processing Magazine, vol.9, issue.2, pp.21-67, 1992. ,
DOI : 10.1109/79.127284
Time-Frequency/Time-Scale Analysis, 1999. ,
On the Quantum Correction For Thermodynamic Equilibrium, Physical Review, vol.40, issue.5, pp.749-759, 1932. ,
DOI : 10.1103/PhysRev.40.749
A general class of estimators for the wigner-ville spectrum of non-stationary processes, Lecture Notes in Control and Information Sciences, vol.62, pp.15-23, 1984. ,
DOI : 10.1007/BFb0004941
Skew angle estimation in document processing using Cohen???s class distributions, Pattern Recognition Letters, vol.20, issue.11-13, pp.11-13, 1999. ,
DOI : 10.1016/S0167-8655(99)00097-5
Skew angle estimation for printed and handwritten documents using the Wigner???Ville distribution, Image and Vision Computing, vol.20, issue.11, pp.813-824, 2002. ,
DOI : 10.1016/S0262-8856(02)00091-4
Estimation de l'inclinaison d'un document arabe manuscrit numérisé par analyse temps-fréquence des histogrammes de projection, Traitement du Signal, vol.26, issue.4, pp.0-0, 2009. ,
Multi-oriented Text Line Extraction from Handwritten Arabic Documents, 2008 The Eighth IAPR International Workshop on Document Analysis Systems, 2008. ,
DOI : 10.1109/DAS.2008.14
URL : https://hal.archives-ouvertes.fr/inria-00347225
Separation of Overlapping and Touching Lines within Handwritten Arabic Documents, 13th International Conference on Computer Analysis of Images and Patterns (CAIP'2009), pp.237-244, 2009. ,
DOI : 10.1007/978-3-642-03767-2_29
URL : https://hal.archives-ouvertes.fr/inria-00435250
Une Approache Générale pour l'Extraction des Lignes des Documents Arabes Anciens Multi-orientées, 12e Colloque International sur le Document Electronique (CIDE.12), 2009. ,
General Text Line Extraction Approach based on Locally Orientation Estimation, Document Recognition and Retrieval XVII, 2010. ,
Segmentation en lignes de documents anciens : application aux documents arabes, Thèse de doctorat, 2010. ,
URL : https://hal.archives-ouvertes.fr/tel-00495972
