Gyrokinetic simulation of collisionless trapped-electron mode turbulence, Physics of Plasmas, vol.12, issue.7, p.72309, 2005. ,
DOI : 10.1063/1.1947447
SLEPc, ACM Transactions on Mathematical Software, vol.31, issue.3, pp.31351-362, 2005. ,
DOI : 10.1145/1089014.1089019
PETSc users manual, 2010. ,
Fast eigenvalue calculations in a massively parallel plasma turbulence code, Parallel Computing, vol.36, issue.5-6, pp.5-6339, 2010. ,
DOI : 10.1016/j.parco.2009.12.001
A Parallel Implementation of the Jacobi-Davidson Eigensolver and Its Application in a Plasma Turbulence Code, Lect. Notes Comp. Sci, vol.6272, pp.101-112, 2010. ,
DOI : 10.1007/978-3-642-15291-7_11
