The local Hölder function of a continuous function - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applied and Computational Harmonic Analysis Année : 2002
This work focuses on the local Hölder exponent as a measure the regularity of a function around a given point. We investigate in detail the structure and the main properties of the local Hölder function (i.e. the function that associates to each point its local Hölder exponent). We prove that it is possible to construct a continuous function with prescribed local and pointwise Hölder functions outside a set of Hausdorff dimension 0.
The-local-holder-function-of-a-continuous-function.pdf (255.37 Ko) Télécharger le fichier
inria-00581029 , version 1 (30-03-2011)
  • HAL Id : inria-00581029 , version 1
Stephane Seuret, Jacques Lévy Véhel. The local Hölder function of a continuous function. Applied and Computational Harmonic Analysis, 2002, 13 (3), pp.263-276. ⟨inria-00581029⟩
Collections
INRIA INRIA2
110 Consultations
139 Téléchargements
