Routing for Data-Collection in Heterogeneous Wireless Sensor Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
Bilel Romdhani
  • Fonction : Auteur
  • PersonId : 881184
Dominique Barthel
  • Fonction : Auteur
  • PersonId : 847534
Fabrice Valois
In this report, we focus on Wireless Sensor Networks (WSNs) in a more realistic setting than classical studies and previous works: we consider wireless sensor nodes having different transmission ranges according to the environment and/or to the wireless chipset. The main consequence of this heterogeneity is the existence of asymmetric links. Such links in a WSN degrade the performance of most protocols which have not been designed to benefit from this heterogeneity and to deal with asymmetric links: most often, these links are essentially pruned. We propose a routing protocol for data collection from sensors nodes to the sink node in heterogeneous WSNs. Our proposal detects and takes benefit from asymmetric links caused by this heterogeneity. Our proposal, denoted MURA (MUltiple RAnges), (1) provides a high delivery ratio, (2) reduces the number of duplicated packets and (3) reduces the number of hop counts by exploiting the asymmetric links.
RR-7586.pdf (616.56 Ko) Télécharger le fichier
inria-00581603 , version 1 (04-04-2011)
inria-00581603 , version 2 (29-11-2011)
inria-00581603 , version 3 (30-11-2011)
  • HAL Id : inria-00581603 , version 1
Bilel Romdhani, Dominique Barthel, Fabrice Valois. Routing for Data-Collection in Heterogeneous Wireless Sensor Networks. [Research Report] RR-7586, 2011. ⟨inria-00581603v1⟩
Collections
INRIA-RRRT
205 Consultations
486 Téléchargements
