Integer Affine Transformations of Parametric Z-polytopes and Applications to Loop Nest Optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Architecture and Code Optimization Année : 2012
The polyhedral model is a well-known compiler optimization framework for the analysis and transformation of affine loop nests. We present a new method concerning a difficult geometric operation that is raised by this model: the integer affine transformation of parametric Z-polytopes. The result of such a transformation is given by a worst-case exponential union of Z-polytopes. We also propose a polynomial algorithm (for fixed dimension), to count points in arbitrary unions of a fixed number of parametric Z-polytopes. We implemented these algorithms and compared them to other existing algorithms, for a set of applications to loop nest analysis and optimization.
inria-00582388 , version 1 (01-04-2011)
Rachid Seghir, Vincent Loechner, Benoit Meister. Integer Affine Transformations of Parametric Z-polytopes and Applications to Loop Nest Optimization. ACM Transactions on Architecture and Code Optimization, 2012, 9 (2), pp.8.1-8.27. ⟨10.1145/2207222.2207224⟩. ⟨inria-00582388⟩
Collections
CNRS INRIA INRIA2
62 Consultations
0 Téléchargements
