MELO 2011 - 1st Workshop on Model-Driven Engineering, Logic and Optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The main goal of this workshop is to bring together two different communities: the Model-Driven Engineering (MDE) community and the logic programming community, to explore how each community can benefit from the techniques of the other. Are both communities friends or foes?
Fichier non déposé
inria-00582526 , version 1 (01-04-2011)
  • HAL Id : inria-00582526 , version 1
Jordi Cabot, Patrick Albert, Grégoire Dupé, Marcos Didonet del Fabro, Scott Lee. MELO 2011 - 1st Workshop on Model-Driven Engineering, Logic and Optimization. ECMFA 2011 - Seventh European Conference on Modelling Foundations and Applications, Jun 2011, Birmingham, United Kingdom. ⟨inria-00582526⟩
146 Consultations
0 Téléchargements
