Atomic snapshots of shared memory, Journal of the ACM, vol.40, issue.4, pp.873-890, 1993. ,
DOI : 10.1145/153724.153741
) Operations, SIAM Journal on Computing, vol.27, issue.2, pp.319-340, 1998. ,
DOI : 10.1137/S0097539795279463
The k-simultaneous consensus problem, Distributed Computing, vol.29, issue.5, pp.185-195, 2010. ,
DOI : 10.1007/s00446-009-0090-8
URL : https://hal.archives-ouvertes.fr/inria-00543100
Multi-writer composite registers, Distributed Computing, pp.175-195, 1994. ,
DOI : 10.1007/BF02280833
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.43.3621
Sharing Memory Robustly in Message Passing Systems, Journal of the ACM, vol.42, issue.1, pp.121-132, 1995. ,
Renaming in an asynchronous environment, Journal of the ACM, vol.37, issue.3, pp.524-548, 1990. ,
DOI : 10.1145/79147.79158
Partial snapshot objects, Proceedings of the twentieth annual symposium on Parallelism in algorithms and architectures, SPAA '08, pp.336-343, 2008. ,
DOI : 10.1145/1378533.1378591
Immediate atomic snapshots and fast renaming, Proceedings of the twelfth annual ACM symposium on Principles of distributed computing , PODC '93, pp.41-51, 1993. ,
DOI : 10.1145/164051.164056
A Simple Algorithmically Reasoned Characterization of Wait-free Computations, Proc. 16th ACM Symposium on Principles of Distributed Computing (PODC'97, pp.189-198, 1997. ,
The BG distributed simulation algorithm, Distributed Computing, vol.14, issue.3, pp.127-146, 2001. ,
DOI : 10.1007/PL00008933
The Heard-Of model: computing in distributed systems with benign faults, Distributed Computing, vol.384, issue.3, pp.49-71, 2009. ,
DOI : 10.1007/s00446-009-0084-6
The renaming problem in shared memory systems: An introduction, Computer Science Review, vol.5, issue.3, 2011. ,
DOI : 10.1016/j.cosrev.2011.04.001
The weakest failure detector for solving consensus, Journal of the ACM, vol.43, issue.4, pp.685-722, 1996. ,
DOI : 10.1145/234533.234549
Unreliable failure detectors for reliable distributed systems, Journal of the ACM, vol.43, issue.2, pp.225-267, 1996. ,
DOI : 10.1145/226643.226647
More Choices Allow More Faults: Set Consensus Problems in Totally Asynchronous Systems, Information and Computation, vol.105, issue.1, pp.132-158, 1993. ,
DOI : 10.1006/inco.1993.1043
The Disagreement Power of an Adversary, Proc. 23th Int'l Symposium on Distributed Computing (DISC'09 Springer-Verlag LNCS #5805, pp.8-21, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00376981
Impossibility of distributed consensus with one faulty process, Journal of the ACM, vol.32, issue.2, pp.374-382, 1985. ,
DOI : 10.1145/3149.214121
The 01-Exclusion Families of Tasks, Proc. 12th In'l Conference on Principles of Distributed Systems (OPODIS'08, pp.246-258, 2008. ,
The extended BG-simulation and the characterization of t-resiliency, Proceedings of the 41st annual ACM symposium on Symposium on theory of computing, STOC '09, pp.85-92, 2009. ,
DOI : 10.1145/1536414.1536428
Turning Adversaries into Friends: Simplified, Made Constructive, and Extended, Proc. 14th Int'l Conference on Principles of Distributed Systems (OPODIS'10), pp.380-394, 2010. ,
DOI : 10.1007/11864219_23
Relating L-Resilience and and Wait-freedom with Hitting Sets, Proc. 12th Int'l Conference on Distributed Computing and Networking (ICDCN'11), pp.191-202, 2011. ,
Recursion in Distributed Computing, Proc. 12th Int'l Symposium on Stabilization, Safety, and Security of Distributed Systems (SSS'10), pp.362-376, 2010. ,
DOI : 10.1007/978-3-642-16023-3_30
Distributed Programming with Tasks, Proc. 14th Int'l Conference on Principles of Distributed Systems (OPODIS'10), pp.205-218, 2010. ,
DOI : 10.1137/S0097539796307698
From Unreliable Objects to Reliable Objects: The Case of Atomic Registers and Consensus, 9th Int'l Conference on Parallel Computing Technologies (PaCT'07), Springer Verlag LNCS LNCS #4671, pp.47-61, 2007. ,
DOI : 10.1007/978-3-540-73940-1_5
Wait-free synchronization, ACM Transactions on Programming Languages and Systems, vol.13, issue.1, pp.124-149, 1991. ,
DOI : 10.1145/114005.102808
Obstruction-free Synchonization: Double-ended Queues as an Example, Proc. 23th Int'l IEEE Conference on Distributed Computing Systems (ICDCS'03), pp.522-529, 2003. ,
The topology of shared-memory adversaries, Proceeding of the 29th ACM SIGACT-SIGOPS symposium on Principles of distributed computing, PODC '10, pp.105-113, 2010. ,
DOI : 10.1145/1835698.1835724
Unifying synchronous and asynchronous message-passing models, Proceedings of the seventeenth annual ACM symposium on Principles of distributed computing , PODC '98, pp.133-142, 1998. ,
DOI : 10.1145/277697.277722
The topological structure of asynchronous computability, Journal of the ACM, vol.46, issue.6, pp.858-923, 1999. ,
DOI : 10.1145/331524.331529
Linearizability: a correctness condition for concurrent objects, ACM Transactions on Programming Languages and Systems, vol.12, issue.3, pp.463-492, 1990. ,
DOI : 10.1145/78969.78972
Help when Needed, but no More: Efficient Read/Write Partial Snapshot, Proc. 23th Int'l Symposium on Distributed Computing (DISC'09 Springer-Verlag LNCS #5805, pp.142-156, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00440392
Visiting Gafni???s Reduction Land: From the BG Simulation to the Extended BG Simulation, Proc. 11th Int'l Symposium on Stabilization, Safety, and Security of Distributed Systems (SSS'09), pp.369-383, 2009. ,
DOI : 10.1007/978-3-642-05118-0_26
The multiplicative power of consensus numbers, Proceeding of the 29th ACM SIGACT-SIGOPS symposium on Principles of distributed computing, PODC '10, pp.26-35, 2010. ,
DOI : 10.1145/1835698.1835705
URL : https://hal.archives-ouvertes.fr/inria-00543130
A Liveness Condition for Concurrent Objects: x-Wait-freedom. To appear in Concurrency and Computation: Practice and experience, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00646908
On asymmetric progress conditions, Proceeding of the 29th ACM SIGACT-SIGOPS symposium on Principles of distributed computing, PODC '10, pp.55-64, 2010. ,
DOI : 10.1145/1835698.1835709
URL : https://hal.archives-ouvertes.fr/inria-00486977
Designing Algorithms for Dependent Process Failures, Future Directions in Distributed Computing #LNCS, vol.47, issue.3, pp.24-28, 2003. ,
DOI : 10.1109/24.740491
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.6.1330
On interprocess communication, Distributed Computing, vol.21, issue.2, pp.77-101, 1986. ,
DOI : 10.1007/BF01786227
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.33.1038
Memory Requirements for Agreement Among Unreliable Asynchronous Processes, of Advances in Comp. Research, pp.163-183, 1987. ,
A Layered Analysis of Consensus, SIAM Journal on Computing, vol.31, issue.4, pp.989-1021, 2002. ,
DOI : 10.1137/S0097539799364006
Conditions on input vectors for consensus solvability in asynchronous distributed systems, Journal of the ACM, vol.50, issue.6, pp.922-954, 2003. ,
DOI : 10.1145/950620.950624
Brief Announcement, Proc. 13th ACM Symposium on Principles of Distributed Computing (PODC'94, p.396, 1994. ,
Iterated Shared Memory Models, Proc. 9th Latin American Symposium Theoretical Informatics (LATIN'10), pp.407-416, 2010. ,
DOI : 10.1007/978-3-642-12200-2_36
An impossibility about failure detectors in the iterated immediate snapshot model, Information Processing Letters, vol.108, issue.3, pp.160-164, 2008. ,
DOI : 10.1016/j.ipl.2008.05.001
The Iterated Restricted Immediate Snapshot (IRIS) Model, 14th Int'l Computing and Combinatorics Conferernce (COCOON'08 Springer-Verlag LNCS 5092, pp.487-496, 2008. ,
A short introduction to failure detectors for asynchronous distributed systems, ACM SIGACT News, vol.36, issue.1, pp.1181-1191, 2009. ,
DOI : 10.1145/1052796.1052806
Communication and Agreement Abstractions for Fault-Tolerant Asynchronous Distributed Systems, Synthesis Lectures on Distributed Computing Theory, vol.1, issue.1, 2010. ,
DOI : 10.2200/S00236ED1V01Y201004DCT002
URL : https://hal.archives-ouvertes.fr/inria-00543036
The Computational Structure of Progress Conditions, Proc. 24th Int'l Symposium on Distributed Computing (DISC'10), pp.221-235, 2010. ,
DOI : 10.1007/978-3-642-15763-9_23
