Mining Service Abstractions (NIER Track) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Several lines of research rely on the concept of service abstractions to enable the organization, the composition and the adaptation of services. However, what is still missing, is a systematic approach for extracting service abstractions out of the vast amount of services that are available all over theWeb. To deal with this issue, we propose an approach for mining service abstractions, based on an agglomerative clustering algorithm. Our experimental ndings suggest that the approach is promising and can serve as a basis for future research.
icse11_2nier-p101-athanasopoulos.pdf (701.25 Ko) Télécharger le fichier
inria-00583780 , version 1 (06-04-2011)
  • HAL Id : inria-00583780 , version 1
Dionysis Athanasopoulos, Apostolos Zarras, Panos Vassiliadis, Valérie Issarny. Mining Service Abstractions (NIER Track). 33rd International Conference on Software Engineering (ICSE), May 2011, Hawaii, United States. pp.4. ⟨inria-00583780⟩
162 Consultations
211 Téléchargements
