Isogeometric Analysis, toward Integration of CAD and FEA, 2009. ,
B??zier surfaces and finite elements for MHD simulations, Journal of Computational Physics, vol.227, issue.16, pp.7423-7445, 2008. ,
DOI : 10.1016/j.jcp.2008.04.001
Collocation at Gaussian Points, SIAM Journal on Numerical Analysis, vol.10, issue.4, 1973. ,
DOI : 10.1137/0710052
Comparisons and physics basis of tokamak transport models and turbulence simulations, Physics of Plasmas, vol.7, issue.3, pp.969-983, 2000. ,
DOI : 10.1063/1.873896
Adaptive isogeometric analysis by local h-refinement with T-splines, Computer Methods in Applied Mechanics and Engineering, vol.199, issue.5-8, pp.264-275, 2010. ,
DOI : 10.1016/j.cma.2008.07.012
Hughes, n-Widths, supinfs, and optimality ratios for the k-version of the isogeometric finite element method, Comput. Methods Appl. Mech. Engrg, p.17261741, 2009. ,
A drift-kinetic Semi-Lagrangian 4D code for ion turbulence simulation, Journal of Computational Physics, vol.217, issue.2, pp.163-194, 1991. ,
DOI : 10.1016/j.jcp.2006.01.023
URL : https://hal.archives-ouvertes.fr/hal-00594856
Nonlinear gyrokinetic equations for tokamak microturbulence, Phys. Fluids, vol.31, issue.9, 1988. ,
DOI : 10.2172/7246860
Fluid moment models for Landau damping with application to the ion-temperature-gradient instability, Physical Review Letters, vol.64, issue.25, pp.3019-3022, 1990. ,
DOI : 10.1103/PhysRevLett.64.3019
Energy conservation in a nonlinear gyrokinetic particlein-cell code for ion-temperature-gradient-driven modes in ?-pinch geometry Phys, Plasmas, vol.9, 2002. ,
Fitting Uncertain Data with NURBS, Proc. 3rd Int. Conf. on Curves and Surfaces in Geometric Design, pp.1-8, 1996. ,
Fast degree elevation and knot insertion for B-spline curves, Computer Aided Geometric Design, vol.22, issue.2, p.183197, 2005. ,
DOI : 10.1016/j.cagd.2004.11.001
Isogeometric analysis: CAD, finite elements, NURBS, exact geometry and mesh refinement, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.39-41, pp.4135-4195, 2005. ,
DOI : 10.1016/j.cma.2004.10.008
URL : https://hal.archives-ouvertes.fr/hal-01513346
Efficient quadrature for NURBS-based isogeometric analysis, Computer Methods in Applied Mechanics and Engineering, vol.199, issue.5-8, pp.301-313, 2010. ,
DOI : 10.1016/j.cma.2008.12.004
Gyrokinetic approach in particle simulation, Physics of Fluids, vol.26, issue.2, p.556, 1983. ,
DOI : 10.1063/1.864140
On high-order corrections to gyrokinetic Vlasov-Poisson equations in the long wavelength limit, 2009. ,
Direct solution of partial difference equations by tensor product methods, Numerische Mathematik, vol.11, issue.1, pp.185-199, 1964. ,
DOI : 10.1007/BF01386067
NURBS curve and surface fitting for reverse engineering, The International Journal of Advanced Manufacturing Technology, vol.21, issue.6, pp.918-927, 1998. ,
DOI : 10.1007/BF01179082
A finite element Poisson solver for gyrokinetic particle simulations in a global field aligned mesh, Journal of Computational Physics, vol.214, issue.2, pp.657-671, 2006. ,
DOI : 10.1016/j.jcp.2005.10.011
A fast algorithm to raise the degree of B-spline curves, Computer Aided Geometric Design, vol.4, pp.253-266, 1991. ,
Arbitrary High-Order Spline Finite Element Solver for the Time Domain Maxwell equations, submitted ,
DOI : 10.1007/s10915-011-9500-8
URL : https://hal.archives-ouvertes.fr/hal-00507758/document
T-spline simplification and local refinement, ACM Transactions on Graphics, vol.23, issue.3, pp.276-283, 2004. ,
DOI : 10.1145/1015706.1015715
The ubiquitous Kronecker product, Journal of Computational and Applied Mathematics, vol.123, issue.1-2, pp.85-100, 2000. ,
DOI : 10.1016/S0377-0427(00)00393-9
