Experiment scenarios, prototypes and report - Iteration 1 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
The task of WP6 is to evaluate the CONNECT technologies under realistic situations. To achieve this goal, WP6 concentrated its effort in the development of a main scenario in the context of the GMES, which required the connection of two very different and independently build systems provided by the industry partners. The first one is a video-surveillance system provided by Thales; the second one, is an implementation of the GSMA Rich Communication Suite provided by DOCOMO. The resulting scenario allows to verify the validity of some of the CONNECT claims and to investigate with the introduction of some of the CONNECT technologies in the context of the integration of real systems. In addition, WP6 started the work of evaluating how the overall CONNECT work cycle can be introduced in the context of industrial prototype development.
connect_WP6_D62.pdf (4.93 Mo) Télécharger le fichier
inria-00584923 , version 1 (11-04-2011)
  • HAL Id : inria-00584923 , version 1
Massimo Paolucci, Bertrand Souville, Rachid Saadi, Gordon S. Blair, Paul Grace, et al.. Experiment scenarios, prototypes and report - Iteration 1. [Research Report] 2011. ⟨inria-00584923⟩
153 Consultations
128 Téléchargements
