Swept volume parametrization for isogeometric analysis, The Mathematics of Surfaces (MoS XIII 2009), pp.19-44, 2009. ,
Isogeometric analysis of free-surface flow, Journal of Computational Physics, vol.230, issue.11, pp.4137-4152, 2011. ,
DOI : 10.1016/j.jcp.2010.11.044
A fully ???locking-free??? isogeometric approach for plane linear elasticity problems: A stream function formulation, Computer Methods in Applied Mechanics and Engineering, vol.197, issue.1-4, pp.160-172, 2007. ,
DOI : 10.1016/j.cma.2007.07.005
ISOGEOMETRIC ANALYSIS: APPROXIMATION, STABILITY AND ERROR ESTIMATES FOR h-REFINED MESHES, Mathematical Models and Methods in Applied Sciences, vol.16, issue.07, pp.1031-1090, 2006. ,
DOI : 10.1142/S0218202506001455
Isogeometric fluid-structure interaction: theory, algorithms, and computations, Computational Mechanics, vol.196, issue.2, pp.3-37, 2008. ,
DOI : 10.1007/s00466-008-0315-x
Isogeometric analysis using T-splines, Computer Methods in Applied Mechanics and Engineering, vol.199, issue.5-8, pp.5-8, 2010. ,
DOI : 10.1016/j.cma.2009.02.036
Iso-geometric Finite Element Analysis Based on Catmull-Clark : ubdivision Solids, Computer Graphics Forum, vol.1, issue.2, pp.1575-1584, 2010. ,
DOI : 10.1111/j.1467-8659.2010.01766.x
Analysis-aware modeling: Understanding quality considerations in modeling for isogeometric analysis, Computer Methods in Applied Mechanics and Engineering, vol.199, issue.5-8, pp.5-8, 2010. ,
DOI : 10.1016/j.cma.2009.09.010
Isogeometric Analysis: Toward Integration of CAD and FEA, 2009. ,
DOI : 10.1002/9780470749081
Studies of refinement and continuity in isogeometric structural analysis, Computer Methods in Applied Mechanics and Engineering, vol.196, issue.41-44, pp.4160-4183, 2007. ,
DOI : 10.1016/j.cma.2007.04.007
Isogeometric analysis of structural vibrations, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.41-43, pp.5257-5296, 2006. ,
DOI : 10.1016/j.cma.2005.09.027
An Isogeometric Analysis approach for the study of the gyrokinetic quasi-neutrality equation, Journal of Computational Physics, vol.231, issue.2, pp.373-393, 2012. ,
DOI : 10.1016/j.jcp.2011.09.004
URL : https://hal.archives-ouvertes.fr/inria-00584672
Adaptive isogeometric analysis by local h-refinement with T-splines, Computer Methods in Applied Mechanics and Engineering, vol.199, issue.5-8, pp.5-8, 2010. ,
DOI : 10.1016/j.cma.2008.07.012
An introduction to isogeometric analysis with application to thermal conduction, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00394151
A new approach to solid modeling with trivariate T-splines based on mesh optimization, Computer Methods in Applied Mechanics and Engineering, vol.200, issue.45-46, pp.3210-3222, 2011. ,
DOI : 10.1016/j.cma.2011.07.004
n-Widths, sup???infs, and optimality ratios for the k-version of the isogeometric finite element method, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.21-26, pp.1726-1741, 2009. ,
DOI : 10.1016/j.cma.2009.01.021
Discrete Coons patches, Computer Aided Geometric Design, vol.16, issue.7, pp.691-700, 1999. ,
DOI : 10.1016/S0167-8396(99)00031-X
Practical Optimization, 1981. ,
Isogeometric analysis of the Cahn???Hilliard phase-field model, Computer Methods in Applied Mechanics and Engineering, vol.197, issue.49-50, pp.4333-4352, 2008. ,
DOI : 10.1016/j.cma.2008.05.003
Isogeometric analysis: CAD, finite elements, NURBS, exact geometry and mesh refinement, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.39-41, pp.39-41, 2005. ,
DOI : 10.1016/j.cma.2004.10.008
Harmonic Volumetric Map-ping for Solid Modeling Applications ,
Volumetric parameterization and trivariate B-spline fitting using harmonic functions, Computer Aided Geometric Design, vol.26, issue.6, pp.648-664, 2009. ,
DOI : 10.1016/j.cagd.2008.09.008
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.140.2120
Using approximate implicitization for domain parameterization in isogeometric analysis, International Conference on Curves and Surfaces, 2010. ,
Isogeometric analysis using polynomial splines over hierarchical T-meshes for two-dimensional elastic solids, Computer Methods in Applied Mechanics and Engineering, vol.200, issue.21-22, pp.21-22, 2011. ,
DOI : 10.1016/j.cma.2011.01.018
Rotation free isogeometric thin shell analysis using PHT-splines, Computer Methods in Applied Mechanics and Engineering, vol.200, issue.47-48, pp.47-48, 2011. ,
DOI : 10.1016/j.cma.2011.08.014
URL : http://mediatum.ub.tum.de/doc/1093124/document.pdf
An Arbitrary High-Order Spline Finite Element Solver for the Time Domain Maxwell Equations, Journal of Scientific Computing, vol.23, issue.3, pp.87-106, 2012. ,
DOI : 10.1007/s10915-011-9500-8
Elliptic Grid Generation Based on Laplace Equations and Algebraic Transformations, Journal of Computational Physics, vol.118, issue.1, pp.38-61, 1995. ,
DOI : 10.1006/jcph.1995.1078
Non-self-overlapping Hermite interpolation mapping: a practical solution for structured quadrilateral meshing, Computer-Aided Design, vol.37, issue.2, pp.271-283, 2005. ,
DOI : 10.1016/j.cad.2004.06.011
Non-self-overlapping structured grid generation on ann-sided surface, International Journal for Numerical Methods in Fluids, vol.53, issue.9, pp.961-982, 2004. ,
DOI : 10.1002/fld.791
Algebraic grid generation on trimmed parametric surface using non-self-overlapping planar Coons patch, International Journal for Numerical Methods in Engineering, vol.60, issue.7, pp.1259-1286, 2004. ,
DOI : 10.1002/nme.1006
Adaptive isogeometric analysis using rational PHT-splines, Computer-Aided Design, vol.43, issue.11, pp.43-1438, 2011. ,
DOI : 10.1016/j.cad.2011.08.026
Trivariate solid T-spline construction from boundary triangulations with arbitrary genus topology, Computer-Aided Design, vol.45, issue.2, pp.351-360, 2013. ,
DOI : 10.1016/j.cad.2012.10.018
Orthogonal grid generation of an irregular region using a local polynomial collocation method, Journal of Computational Physics, vol.243, 2013. ,
DOI : 10.1016/j.jcp.2013.01.005
Direct product volume parameterization using harmonic fields, Proceedings of IEEE International Conference on Shape Modeling and Applications (SMI '10), pp.3-12, 2010. ,
DOI : 10.1109/smi.2010.10
Parameterization of Star-Shaped Volumes Using Green???s Functions, Proceedings of Geometric Modeling and Processing (GMP '10), pp.219-235, 2010. ,
DOI : 10.1007/978-3-642-13411-1_15
Optimal analysis-aware parameterization of computational domain in 3D isogeometric analysis, Computer-Aided Design, vol.45, issue.4, 2013. ,
DOI : 10.1016/j.cad.2011.05.007
URL : https://hal.archives-ouvertes.fr/inria-00539616
Parameterization of computational domain in isogeometric analysis: Methods and comparison, Computer Methods in Applied Mechanics and Engineering, vol.200, issue.23-24, pp.200-223, 2011. ,
DOI : 10.1016/j.cma.2011.03.005
Analysis-suitable volume parameterization of multi-block computational domain in isogeometric applications, Computer-Aided Design, vol.45, issue.2, pp.395-404, 2013. ,
DOI : 10.1016/j.cad.2012.10.022
URL : https://hal.archives-ouvertes.fr/hal-00685002
Solid T-spline construction from boundary representations for genus-zero geometry, Computer Methods in Applied Mechanics and Engineering, vol.249, issue.252, pp.249-252185, 2012. ,
DOI : 10.1016/j.cma.2012.01.014
Conformal solid T-spline construction from boundary T-spline representations . Computational Mechanics, pp.10-1007, 2013. ,
DOI : 10.1007/s00466-012-0787-6
An improved nearly-orthogonal structured mesh generation system with smoothness control functions, Journal of Computational Physics, vol.231, issue.16, pp.231-5289, 2012. ,
DOI : 10.1016/j.jcp.2012.04.043
2D nearly orthogonal mesh generation with controls on distortion function, Journal of Computational Physics, vol.218, issue.2, pp.549-571, 2006. ,
DOI : 10.1016/j.jcp.2006.02.023
