Well-posedness of the frequency permutation problem in sparse filter estimation with lp minimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A well-known issue in blind convolutive source separation is that the sources and filters are at best identifiable up to an arbitrary scaling and permutation at each frequency bin. We propose to exploit the sparsity of the filters as a consistency measure for correcting such permutations. We show that the permutation is well-posed, up to a global permutation, under appropriate sparsity hypotheses on the filters. A greedy combinatorial algorithm is proposed for permutation recovery. Its empirical performance shows that the time-domain sparsity of the filters allows to recover permutations much beyond theoretical predictions.
spars1p.pdf (73.13 Ko) Télécharger le fichier
inria-00587789 , version 1 (21-04-2011)
  • HAL Id : inria-00587789 , version 1
Alexis Benichoux, Prasad Sudhakar, Rémi Gribonval. Well-posedness of the frequency permutation problem in sparse filter estimation with lp minimization. Signal Processing with Adaptive Sparse Structured Representations, Jun 2011, Edinburgh, United Kingdom. ⟨inria-00587789⟩
141 Consultations
117 Téléchargements
