RES: computing the interactions between real and virtual objects in video sequences - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1995
Possibilities for dynamic interactions of people with machines created by combination of virtual reality and communication networking provide new interesting problems at the intersection of two domains (among others): Computer Vision and Computer Graphics. In this paper, a technical solution to one of these problems is presented to automate the mixing of real and synthetic objects in a same animated video sequence. Current approaches usually involve mainly 2D-based eeects and rely heavily on human expertise and interaction. We aim at achieving a close binding between 3D-based analysis and synthesis techniques to compute the interaction between a real scene captured in a sequence of calibrated images, and a computer-generated environment.
RES_95.pdf (831.9 Ko) Télécharger le fichier
inria-00588887 , version 1 (26-04-2011)
inria-00588887 , version 2 (05-11-2015)
  • HAL Id : inria-00588887 , version 2
Pierre Jancène, Fabrice Neyret, Xavier Provot, Jean-Philippe Tarel, Jean-Marc Vézien, et al.. RES: computing the interactions between real and virtual objects in video sequences. Networked realities'95, Oct 1995, Boston, United States. ⟨inria-00588887v2⟩
Collections
INRIA INRIA2
151 Consultations
139 Téléchargements
