New interface
Journal articles
A supervised clustering approach for fMRI-based inference of brain states
Abstract : We propose a method that combines signals from many brain regions observed in functional Magnetic Resonance Imaging (fMRI) to predict the subject's behavior during a scanning session. Such predictions suffer from the huge number of brain regions sampled on the voxel grid of standard fMRI data sets: the curse of dimensionality. Dimensionality reduction is thus needed, but it is often performed using a univariate feature selection procedure, that handles neither the spatial structure of the images, nor the multivariate nature of the signal. By introducing a hierarchical clustering of the brain volume that incorporates connectivity constraints, we reduce the span of the possible spatial configurations to a single tree of nested regions tailored to the signal. We then prune the tree in a supervised setting, hence the name supervised clustering, in order to extract a parcellation (division of the volume) such that parcel-based signal averages best predict the target information. Dimensionality reduction is thus achieved by feature agglomeration, and the constructed features now provide a multi-scale representation of the signal. Comparisons with reference methods on both simulated and real data show that our approach yields higher prediction accuracy than standard voxel-based approaches. Moreover, the method infers an explicit weighting of the regions involved in the regression or classification task.
Document type :
Journal articles
Complete list of metadata
Cited literature [37 references]  Display  Hide  Download
https://hal.inria.fr/inria-00589201
Contributor : Gaël Varoquaux Connect in order to contact the contributor
Submitted on : Wednesday, April 27, 2011 - 11:44:31 PM
Last modification on : Tuesday, October 25, 2022 - 4:21:57 PM
Long-term archiving on: : Thursday, July 28, 2011 - 2:53:42 AM
supervised_clustering_vm_revie...
Identifiers
Citation
Vincent Michel, Alexandre Gramfort, Gaël Varoquaux, Evelyn Eger, Christine Keribin, et al.. A supervised clustering approach for fMRI-based inference of brain states. Pattern Recognition, 2011, epub ahead of print. ⟨10.1016/j.patcog.2011.04.006⟩. ⟨inria-00589201⟩
Share
Metrics
Record views
724
Files downloads
416
