Sparse Meshless Models of Complex Deformable Solids - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2011
A new method to simulate deformable objects with heterogeneous material properties and complex geometries using an arbitrary number of control frames is presented. Given a volumetric map of the material properties of an object and a number of control nodes, a distribution of the nodes is computed automatically, as well as the associated shape functions. Reference frames are attached to the nodes, and deformations are applied to the object using linear blend skinning. A continuum mechanics formulation is derived from the displacements and the material properties. We introduce novel material-aware shape functions in place of the traditional radial basis functions used in meshless frameworks. These allow coarse deformation functions to very efficiently resolve nonuniform stiffnesses. Complex models can thus be simulated at high frame rates using a small number of control nodes.
Mots clés
main.pdf (6.75 Mo) Télécharger le fichier
video.avi (17.08 Mo) Télécharger le fichier
Format : Figure, Image
Format : Vidéo
inria-00589204 , version 1 (04-05-2011)
inria-00589204 , version 2 (18-08-2011)
inria-00589204 , version 3 (19-08-2011)
François Faure, Benjamin Gilles, Guillaume Bousquet, Dinesh K. Pai. Sparse Meshless Models of Complex Deformable Solids. ACM Transactions on Graphics, 2011, Proceedings of SIGGRAPH'2011, 30 (4), pp.Article No. 73. ⟨10.1145/2010324.1964968⟩. ⟨inria-00589204v3⟩
1146 Consultations
5597 Téléchargements
