Sparse Meshless Models of Complex Deformable Solids - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2011
A new method to simulate deformable objects with heterogeneous material properties and complex geometries using an arbitrary num- ber of control frames is presented. Given a volumetric map of the material properties of an object and a number of control nodes, a distribution of the nodes is computed automatically, as well as the associated shape functions. Reference frames are attached to the nodes, and deformations are applied to the object using lin- ear blend skinning. A continuum mechanics formulation is de- rived from the displacements and the material properties. We in- troduce novel material-aware shape functions in place of the tradi- tional radial basis functions used in meshless frameworks. These allow coarse deformation functions to very efficiently resolve non- uniform stiffnesses. Complex models can thus be simulated at high frame rates using a small number of control nodes.
main.pdf (1.33 Mo) Télécharger le fichier
Format : Figure, Image
inria-00589204 , version 1 (04-05-2011)
inria-00589204 , version 2 (18-08-2011)
inria-00589204 , version 3 (19-08-2011)
  • HAL Id : inria-00589204 , version 1
François Faure, Benjamin Gilles, Guillaume Bousquet, Dinesh K. Pai. Sparse Meshless Models of Complex Deformable Solids. ACM Transactions on Graphics, 2011, Proceedings of SIGGRAPH'2011. ⟨inria-00589204v1⟩
1147 Consultations
5598 Téléchargements
