A Framework for Document-Driven Workflow Systems, Business Process Management, pp.285-301, 2005. ,
DOI : 10.1007/11538394_19
Workflow Management: Models, Methods, and Systems, 2002. ,
Computation orchestration Software and Systems Modeling, pp.83-110, 2007. ,
WIDE-a distributed architecture for workflow management, Proceedings Seventh International Workshop on Research Issues in Data Engineering. High Performance Database Management for Large-Scale Applications, p.76, 1997. ,
DOI : 10.1109/RIDE.1997.583705
A specification language for the WIDE workflow model, Proceedings of the 1998 ACM symposium on Applied Computing , SAC '98, pp.197-199, 1998. ,
DOI : 10.1145/330560.330669
Business artifacts: An approach to operational specification, IBM Systems Journal, vol.42, issue.3, pp.428-445, 2003. ,
DOI : 10.1147/sj.423.0428
Artifact-Centric Business Process Models: Brief Survey of Research Results and Challenges, On the Move to Meaningful Internet Systems (OTM) Conferences, ser, pp.1152-1163, 2008. ,
DOI : 10.1007/978-3-540-88873-4_17
Modeling and verifying active XML artifacts, IEEE Data Eng. Bull, vol.32, issue.3, pp.10-15, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00429484
The Active XML project: an overview, The VLDB Journal, vol.7, issue.4, pp.1019-1040, 2008. ,
DOI : 10.1007/s00778-007-0049-y
Static analysis of active XML systems, Symposium on Principles of Database Systems (PODS), pp.221-230, 2008. ,
Distributed active XML and service interfaces INRIA, RR no 7082 7082, 2009. ,
Complexity of Data Tree Patterns over XML Documents, Mathematical Foundations of Computer Science (MFCS), ser, pp.278-289, 2008. ,
DOI : 10.1007/978-3-540-85238-4_22
Containment and equivalence for a fragment of XPath, Journal of the ACM, vol.51, issue.1, pp.2-45, 2004. ,
DOI : 10.1145/962446.962448
Inventory Decisions in Dell's Supply Chain, Interfaces, vol.34, issue.3, pp.191-205, 2004. ,
DOI : 10.1287/inte.1030.0068
Xquery 1.0: An XML query language, W3C, Tech. Rep. Editors, 2007. ,
XPath query containment, ACM SIGMOD Record, vol.33, issue.1, pp.101-109, 2004. ,
DOI : 10.1145/974121.974140
