The HiPEAC Vision, Network of Excellence of High Performance and Embedded Architecture and Compilation, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-01491758
Compilation and virtualization in the HiPEAC vision, Proceedings of the 47th Design Automation Conference on, DAC '10, 2010. ,
DOI : 10.1145/1837274.1837302
The worst-case execution-time problem???overview of methods and survey of tools, ACM Transactions on Embedded Computing Systems, vol.7, issue.3, pp.1-53, 2008. ,
DOI : 10.1145/1347375.1347389
A real-time Java chip-multiprocessor ARM Jazelle technology, TECS, vol.10, issue.1, 2010. ,
Processor virtualization and split compilation for heterogeneous multicore embedded systems, Proceedings of the 47th Design Automation Conference on, DAC '10, 2010. ,
DOI : 10.1145/1837274.1837303
URL : https://hal.archives-ouvertes.fr/inria-00472274
Portable worst-case execution time analysis using Java Byte Code, Proceedings 12th Euromicro Conference on Real-Time Systems. Euromicro RTS 2000, pp.81-88, 2000. ,
DOI : 10.1109/EMRTS.2000.853995
Low-level analysis of a portable Java byte code WCET analysis framework, Proceedings Seventh International Conference on Real-Time Computing Systems and Applications, pp.39-46, 2000. ,
DOI : 10.1109/RTCSA.2000.896369
Fast and precise WCET prediction by separated cache and path analyses, Real-Time Systems, vol.18, issue.2/3, pp.157-179, 2000. ,
DOI : 10.1023/A:1008141130870
Timing analysis for instruction caches, Real-Time Systems, vol.18, issue.2/3, pp.217-247, 2000. ,
DOI : 10.1023/A:1008145215849
The influence of processor architecture on the design and the results of WCET tools, Proceedings of the IEEE, vol.91, issue.7, pp.1038-1054, 2003. ,
DOI : 10.1109/JPROC.2003.814618
WCET Analysis of Multi-level Non-inclusive Set-Associative Instruction Caches, 2008 Real-Time Systems Symposium, pp.456-466, 2008. ,
DOI : 10.1109/RTSS.2008.10
FICO: A Fast Instruction Cache Optimizer, SCOPES, pp.388-402, 2003. ,
DOI : 10.1007/978-3-540-39920-9_27
WCET-driven Cache-based Procedure Positioning Optimizations, 2008 Euromicro Conference on Real-Time Systems, pp.321-330, 2008. ,
DOI : 10.1109/ECRTS.2008.20
A modular worstcase execution time analysis tool for Java processors, RTAS, pp.47-57, 2008. ,
Modeling the function cache for worstcase execution time analysis, DAC, pp.471-476, 2007. ,
Worst-case execution time analysis for a Java processor, Software: Practice and Experience, pp.507-542, 2010. ,
DOI : 10.1002/spe.968
Design and implementation of a comprehensive real-time java virtual machine, Proceedings of the 7th ACM & IEEE international conference on Embedded software , EMSOFT '07, pp.249-258, 2007. ,
DOI : 10.1145/1289927.1289967
Design of the Java HotSpot TM client compiler for Java 6, pp.1-7, 2008. ,
Abstract interpretation, Proceedings of the 4th ACM SIGACT-SIGPLAN symposium on Principles of programming languages , POPL '77, pp.238-252, 1977. ,
DOI : 10.1145/512950.512973
URL : https://hal.archives-ouvertes.fr/inria-00528590
Timing predictability of cache replacement policies, Real-Time Systems, vol.28, issue.2???3, pp.99-122, 2007. ,
DOI : 10.1007/s11241-007-9032-3
Using a worst-case execution time tool for real-time verification of the DEBIE software, Data Systems in Aerospace (DASIA), 2000. ,
Computing maximum task execution times ? a graph based approach, RTSS Constraint Integer Programming, pp.67-91, 1153. ,
Quality and speed in linearscan register allocation, PLDI. ACM, pp.142-151, 1998. ,
MediaBench: A Tool for Evaluating and Synthesizing Multimedia and Communications Systems, MICRO, pp.330-335, 1997. ,
