The Landscape of Parallel Computing Research: A View from Berkeley, EECS Department, 2006. ,
Parallel programming, Proceedings of the 45th annual conference on Design automation, DAC '08, pp.7-11, 2008. ,
DOI : 10.1145/1391469.1391474
Spidle: A DSL Approach to Specifying Streaming Applications, Proc. 2nd international conference on Generative programming and component engineering, pp.1-17, 2003. ,
DOI : 10.1007/978-3-540-39815-8_1
StreamIt: A Language for Streaming Applications, Proc. 11th International Conference on Compiler Construction, pp.179-196, 2002. ,
DOI : 10.1007/3-540-45937-5_14
Processor virtualization and split compilation for heterogeneous multicore embedded systems, Proceedings of the 47th Design Automation Conference on, DAC '10, 2010. ,
DOI : 10.1145/1837274.1837303
URL : https://hal.archives-ouvertes.fr/inria-00472274
LLVM: A compilation framework for lifelong program analysis & transformation, International Symposium on Code Generation and Optimization, 2004. CGO 2004., 2004. ,
DOI : 10.1109/CGO.2004.1281665
2006 -Common Language Infrastructure (CLI), Partitions I to VI, International Organization for Standardization and International Electrotechnical Commission ,
CLI Back-End in GCC, GCC Developers' Summit, pp.111-116, 2007. ,
Comparing the size of .NET applications with native code, Proceedings of the 3rd IEEE/ACM/IFIP international conference on Hardware/software codesign and system synthesis, CODES+ISSS '05, pp.99-104, 2005. ,
DOI : 10.1145/1084834.1084862
An Experimental Environment Validating the Suitability of CLI as an Effective Deployment Format for Embedded Systems, International Conference on HiPEAC, ser. LNCS, pp.130-144, 2008. ,
DOI : 10.1007/978-3-540-77560-7_10
CLI-based compilation flows for the C language, 2010 International Conference on Embedded Computer Systems: Architectures, Modeling and Simulation, pp.162-169, 2010. ,
DOI : 10.1109/ICSAMOS.2010.5642069
URL : https://hal.archives-ouvertes.fr/inria-00505640
Mass produced software components, Proc. NATO Software Engineering Conference, pp.138-155, 1968. ,
Component software: beyond object-oriented programming, 1998. ,
Distributed Object Models for Multi-Processor SoC's, with Application to Low-power Multimedia Wireless Systems, Proceedings of the Design Automation & Test in Europe Conference, pp.482-487, 2006. ,
DOI : 10.1109/DATE.2006.243833
The Fractal Composition Framework, The ObjectWeb Consortium -Interface Specification Supporting heterogeneous architecture descriptions in an extensible toolset, 29th International Conference on Software Engineering, 2002. ,
The OpenCL specification version 1.0, Khronos OpenCL Working Group, Tech. Rep, p.2, 2009. ,
THINK: A Software Framework for Component-based Operating System Kernels, USENIX Annual Technical Conference, 2002. ,
The FRACTAL component model and its support in Java, Software Practice and Experience, special issue on Experiences with Autoadaptive and Reconfigurable Systems, pp.1257-1284, 2006. ,
DOI : 10.1002/spe.767
The Fractal Component Model, v2 A Componentbased Approach for MPSoC SW Design: Experience with OS Customization for H.264 Decoding, Proc. 3rd Workshop on Embedded Systems for Real-Time Multimedia, ESTImedia 2005, pp.95-100, 2003. ,
Inter-block Scoreboard Scheduling in a JIT Compiler for VLIW Processors, The 14th International Euro-Par Conference on Parallel and Distributed Computing, 2008. ,
DOI : 10.1007/978-3-540-85451-7_40
