Vapor SIMD: Auto-Vectorize Once, Run Everywhere - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Erven Rohou
Ira Rosen
  • Fonction : Auteur
Kevin Williams
  • Fonction : Auteur
  • PersonId : 880447
David Yuste
  • Fonction : Auteur
  • PersonId : 885836
Ayal Zaks
  • Fonction : Auteur
Just-in-Time (JIT) compiler technology offers portability while facilitating target- and context-specific specialization. Single-Instruction-Multiple-Data (SIMD) hardware is ubiquitous and markedly diverse, but can be difficult for JIT compilers to efficiently target due to resource and budget constraints. We present our design for a synergistic auto-vectorizing compilation scheme. The scheme is composed of an aggressive, generic offline stage coupled with a lightweight, target-specific online stage. Our method leverages the optimized intermediate results provided by the first stage across disparate SIMD architectures from different vendors, having distinct characteristics ranging from different vector sizes, memory alignment and access constraints, to special computational idioms.We demonstrate the effectiveness of our design using a set of kernels that exercise innermost loop, outer loop, as well as straight-line code vectorization, all automatically extracted by the common offline compilation stage. This results in performance comparable to that provided by specialized monolithic offline compilers. Our framework is implemented using open-source tools and standards, thereby promoting interoperability and extendibility.
Autre [cs.OH]
CGO2011-OK.pdf (381.99 Ko) Télécharger le fichier
inria-00589692 , version 1 (30-04-2011)
  • HAL Id : inria-00589692 , version 1
Dorit Nuzman, Sergei Dyshel, Erven Rohou, Ira Rosen, Kevin Williams, et al.. Vapor SIMD: Auto-Vectorize Once, Run Everywhere. International Symposium on Code Generation and Optimization, Olivier Temam, Apr 2011, Chamonix, France. ⟨inria-00589692⟩
489 Consultations
637 Téléchargements
