Electromagnetic casting inverse problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
The aim of this paper is to solve an inverse problem concerning electromagnetic casting of molten metals. We are interested in locating suitable inductors around a molten metal so that its equilibrium shape be as near as possible to a desired one. In this paper we derive an algorithm using Simultaneous Analysis and Design (SAND), this mathematical programming method is stated for the inverse problem. The resulting optimization problem is solved with FAIPA, a feasible directions interior point algorithm.
Fichier non déposé
inria-00589759 , version 1 (01-05-2011)
  • HAL Id : inria-00589759 , version 1
Alfredo Canelas, José Herskovits, Jean Rodolphe Roche. Electromagnetic casting inverse problem. International Conference on Engineering Optimization - IngOpt 2008, Jun 2008, Rio de Janeiro, Brazil. ⟨inria-00589759⟩
163 Consultations
0 Téléchargements
