IRMA - Institut de Recherche Mathématique Avancée, LSIIT - Laboratoire des Sciences de l'Image, de l'Informatique et de la Télédétection, Inria Nancy - Grand Est, IECL - Institut Élie Cartan de Lorraine
IECL - Institut Élie Cartan de Lorraine (Université de Lorraine, Boulevard des Aiguillettes BP 70239 54506 Vandoeuvre-les-Nancy Cedex
Ile du Saulcy - 57 045 Metz Cedex 01 - France)
Abstract : The inverse problem concerning electromagnetic casting of molten metals consists of looking for an electric current density distribution such that the induced electromagnetic field makes a given mass of liquid metal acquire a predefined shape. This problem is formulated here as an optimization problem where the positions of a finite set of inductors are the design variables. Two different formulations for this optimization problem for the two-dimensional case are proposed. The first one minimizes the difference between the target and the equilibrium shapes while the second approach minimizes the L 2 norm of a fictitious surface pressure that makes the target shape to be in mechanical equilibrium. The optimization problems are solved using Feasible Arc Interior Point Algorithm, a line search interior-point algorithm for nonlinear optimization. Some examples are presented to show the effectiveness of the proposed approaches.
https://hal.inria.fr/inria-00589958
Contributeur : Jean Rodolphe Roche
Soumis le : lundi 2 mai 2011 - 23:18:34
Dernière modification le : mercredi 14 mars 2018 - 16:44:25
