Smoothed Local Symmetries and Their Implementation, The International Journal of Robotics Research, vol.3, issue.3, pp.36-61, 1984. ,
DOI : 10.1177/027836498400300302
A Computational Approach to Edge Detection, IEEE Transactions on Pattern Analysis and Machine Intelligence, issue.6, pp.8679-698, 1986. ,
Using Canny's criteria to derive a recursively implemented optimal edge detector, International Journal of Computer Vision, vol.1, issue.2, pp.167-187, 1987. ,
DOI : 10.1007/BF00123164
Parallel and deterministic algorithms from mrf's: Surface reconstruction, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.13, issue.5, pp.410-412, 1991. ,
A common framework for image segmentation, [1990] Proceedings. 10th International Conference on Pattern Recognition, pp.227-243, 1991. ,
DOI : 10.1109/ICPR.1990.118154
Robust classifiers by mixed adaptation, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.13, issue.6, pp.552-567, 1991. ,
DOI : 10.1109/34.87342
Figure-ground discrimination: a combinatorial optimization approach, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.15, issue.9, pp.899-914, 1993. ,
DOI : 10.1109/34.232076
Neural Networks and Graph K-Partitioning, Complex Systems, vol.3, issue.6, pp.531-576, 1989. ,
Neural Networks and Combinatorial Optimisation: A Study of NP-Complete Graph Problems, Neural Networks: Advances and Applications, pp.165-213, 1991. ,
Snakes: Active contour models, International Journal of Computer Vision, vol.5, issue.6035, pp.321-331, 1988. ,
DOI : 10.1007/BF00133570
Gestalt Psychology, 1980. ,
Mean-field theory for optimization problems, Journal de Physique Lettres, vol.46, issue.17, pp.763-770, 1985. ,
DOI : 10.1051/jphyslet:019850046017076300
URL : https://hal.archives-ouvertes.fr/jpa-00232896
Trace inference, curvature consistency, and curve detection, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.11, issue.8, pp.823-839, 1989. ,
DOI : 10.1109/34.31445
A NEW METHOD FOR MAPPING OPTIMIZATION PROBLEMS ONTO NEURAL NETWORKS, International Journal of Neural Systems, vol.01, issue.01, pp.3-22, 1989. ,
DOI : 10.1142/S0129065789000414
Track finding with neural networks. Nuclear Instruments and Methods in Physics Research, pp.537-545, 1989. ,
Separating Figure from Ground with a Boltzmann Machine, Vision, Brain, and Cooperative Computation, pp.703-724, 1988. ,
Structural Saliency: The Detection of Globally Salient Structures Using a Locally Connected Network, Proc. IEEE International Conference on Computer Vision, pp.321-327, 1988. ,
Introduction to Phases Transitions and Critical Phenomena, 1971. ,
Graph Partitioning Using Annealed Neural Networks, Int. Joint Conf. on Neural Networks, pp.521-528, 1989. ,
Mean field approximation using compound Gauss-Markov random field for edge detection and image restoration, International Conference on Acoustics, Speech, and Signal Processing, pp.2193-2196, 1990. ,
DOI : 10.1109/ICASSP.1990.115992
