Smooth Surface Reconstruction from Image Sequences - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1995
This paper addresses the problem of 3D surface reconstruction using image sequences. It has been shown that shape recovery from three or more occluding contours of the surface is possible given a known camera motion. Recent algorithms allow the estimation of a 3D depth map of points on extremal contours. We present our approach which is based on local approximations up to order two of the surface. Such reconstruction must then be followed by a global surface description stage. This is done by constructing a triangulation of the reconstructed points and by performing a regularisation step in order to correct perturbations which affect the reconstruction. Experiments on real data were conducted which have proved the reliability of the method.
icip95.pdf (486.07 Ko) Télécharger le fichier
inria-00590050 , version 1 (03-05-2011)
Edmond Boyer, Marie-Odile Berger. Smooth Surface Reconstruction from Image Sequences. IEEE International Conference on Image Processing (ICIP '95), Oct 1995, Washington, United States. pp.398--401, ⟨10.1109/ICIP.1995.529730⟩. ⟨inria-00590050⟩
37 Consultations
170 Téléchargements
