Conic Reconstruction and Correspondence from Two Views - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Pattern Analysis and Machine Intelligence Année : 1996
Conics are widely accepted as one of the most fundamental image features together with points and line segments. The problem of space reconstruction and correspondence of two conics from two views is addressed in this paper. It is shown that there are two independent polynomial conditions on the corresponding pair of conics across two views, given the relative orientation of the two views. These two correspondence conditions are derived algebraically and one of them is shown to be fundamental in establishing the correspondences of conics. A unified closed-form solution is also developed for both projective reconstruction of conics in space from two views for uncalibrated cameras and metric reconstruction from calibrated cameras. Experiments are conducted to demonstrate the discriminality of the correspondence conditions and the accuracy and stability of the reconstruction both for simulated and real images.
Quan-pami96.pdf (514.97 Ko) Télécharger le fichier
inria-00590058 , version 1 (03-05-2011)
Long Quan. Conic Reconstruction and Correspondence from Two Views. IEEE Transactions on Pattern Analysis and Machine Intelligence, 1996, 18 (2), pp.151--160. ⟨10.1109/34.481540⟩. ⟨inria-00590058⟩
118 Consultations
558 Téléchargements
