Robot Stereo-hand Coordination for Grasping Curved Parts
In this paper we present an algorithm to compute a set-point (i.e. a position to be reached by robot end-effector) automatically from conic features interactively selected by an operator onto the object. We then use a visual servoing algorithm to guide the gripper to its ?nal position. We have tested this algorithm in trying to open a valve with a 6 degree of freedom robot arm, using only visual information and without any model of the valve.
