On computing exact visual hulls of solids bounded by smooth surfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
This paper presents a method for computing the visual hull that is based on two novel representations: the rim mesh, which describes the connectivity of contour generators on the object surface; and the visual hull mesh, which describes the exact structure of the surface of the solid formed by intersecting a finite number of visual cones. We describe the topological features of these meshes and show how they can be identified in the image using epipolar constraints. These constraints are used to derive an image-based practical reconstruction algorithm that works with weakly calibrated cameras. Experiments on synthetic and real data validate the proposed approach.
LazebnikBoyerPonce_cvpr01.pdf (383.87 Ko) Télécharger le fichier
inria-00590147 , version 1 (03-05-2011)
Svetlana Lazebnik, Edmond Boyer, Jean Ponce. On computing exact visual hulls of solids bounded by smooth surfaces. IEEE International Conference on Computer Vision and Pattern Recognition (CVPR '01), Dec 2001, Kauai, United States. pp.151--161, ⟨10.1109/CVPR.2001.990469⟩. ⟨inria-00590147⟩
128 Consultations
240 Téléchargements
