Human Pose Estimation from Silhouettes. A Consistent Approach Using Distance Level Sets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
We present a novel similarity measure (likelihood) for estimating three-dimensional human pose from image silhouettes in model-based vision applications. One of the challenges in such approaches is the construction of a model-to-image likelihood that truly reflects the good configurations of the problem. This is hard, commonly due to the violation of consistency principle resulting in the introduction of spurious, unrelated peaks/minima that make the search for model localization difficult. We introduce an entirely continuous formulation which enforces model estimation consistency by means of an attraction/explanation silhouette-based term pair. We subsequently show how the proposed method provides significant consolidation and improved attraction zone around the desired likelihood configurations and elimination of some of the spurious ones. Finally, we present a skeleton-based smoothing method for the image silhouettes that stabilizes and accelerates the search process.
wscg.pdf (233.67 Ko) Télécharger le fichier
inria-00590165 , version 1 (03-05-2011)
  • HAL Id : inria-00590165 , version 1
Cristian Sminchisescu, Alexandru C Telea. Human Pose Estimation from Silhouettes. A Consistent Approach Using Distance Level Sets. 10th International Conference on Computer Graphics,Visualization and Computer Vision (WSCG '02), Feb 2002, Pilsen, Czech Republic. ⟨inria-00590165⟩
5584 Consultations
522 Téléchargements
