Evidential modeling for pose estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Pose estimation involves reconstructing the configura- tion of a moving body from images sequences. In this paper we present a general framework for pose esti- mation of unknown objects based on Shafer's eviden- tial reasoning. During learning an evidential model of the object is built, integrating different image fea- tures to improve both estimation robustness and pre- cision. All the measurements coming from one or more views are expressed as belief functions, and com- bined through Dempster's rule. The best pose esti- mate at each time step is then extracted from the resulting belief function by probabilistic approxima- tion. The choice of a sufficiently dense training set is a critical problem. Experimental results concerning a human tracking system are shown.
s028.pdf (416.61 Ko) Télécharger le fichier
pre028.ppt (7.13 Mo) Télécharger le fichier
Format : Autre
inria-00590191 , version 1 (06-05-2011)
  • HAL Id : inria-00590191 , version 1
Fabio Cuzzolin, Ruggero Frezza. Evidential modeling for pose estimation. 4th International Symposium on Imprecise Probabilities and Their Applications (ISIPTA'05), Jul 2005, Pittsburgh, United States. ⟨inria-00590191⟩
59 Consultations
47 Téléchargements
