An Active Contour Model Based on Splines and Separating Forces to Detect the Left Ventricle in Scintigraphic Images
In this paper we present a novel method for the segmentation of scintigraphic images in order to detect the two ventricles of the heart. The method is based on the active contour model using a region based approach and parametric representation of the contour. The novel aspect of the method is that we have integrated separating forces between the two ventricles in the active contour model. The method has been applied on several scintigraphic images and compared to "active contour without edges" model. The results are satisfactory.
