A metric for ARMA processes, IEEE Transactions on Signal Processing, vol.48, issue.4, pp.1164-1170, 2000. ,
DOI : 10.1109/78.827549
Subspace angles and distances between arma models, Systems and Control Letters, vol.1, issue.2, p.7, 2002. ,
Unstable systems and feedback: The gap metric, Proc. 18th Allerton Conference on Communications, Control, and Computers, pp.380-385, 1980. ,
A ??-gap distance for uncertain and nonlinear systems, Proceedings of the 38th IEEE Conference on Decision and Control (Cat. No.99CH36304), p.7, 1999. ,
DOI : 10.1109/CDC.1999.831313
The graph metric for unstable plants and robustness estimates for feedback stability, AC, vol.29, pp.403-417, 1984. ,
Hilbert space embeddings in dynamical systems, Proceedings of the 13th IFAC symposium on system identification, pp.760-767, 2003. ,
Average divergence distance as a statistical discrimination measure for hidden Markov models, IEEE Transactions on Audio, Speech and Language Processing, vol.14, issue.3, 2004. ,
DOI : 10.1109/TSA.2005.858059
Metrics and similarity measures for hidden Markov models, Proceedings of ISMB 1999, pp.178-186, 1999. ,
Fast approximation of Kullback-Leibler distance for dependence trees and hidden Markov models, IEEE Signal Processing Letters, vol.10, issue.4, pp.115-118, 2003. ,
DOI : 10.1109/LSP.2003.809034
On Information and Sufficiency, The Annals of Mathematical Statistics, vol.22, issue.1, pp.79-86, 1951. ,
DOI : 10.1214/aoms/1177729694
A Probabilistic Distance Measure for Hidden Markov Models, AT&T Technical Journal, vol.64, issue.2, pp.391-408, 1985. ,
DOI : 10.1002/j.1538-7305.1985.tb00439.x
Learning distance functions using equivalence relations, pp.3-11, 2003. ,
Learning distance functions for image retrieval, pp.570-577, 2004. ,
Integrating constraints and metric learning in semi-supervised clustering, Twenty-first international conference on Machine learning , ICML '04, 2004. ,
DOI : 10.1145/1015330.1015360
Learning a distance metric from relative comparisons, Advances in Neural Information Processing Systems, 2004. ,
Distance metric learning with kernels, Proceedings of the International Conference on Artificial Intelligence, 2003. ,
Learning metrics via discriminant kernels and multidimensional scaling: Toward expected euclidean representation, ICML'03. (Hong Kong, 2003. ,
Using clustering to learn distance functions for supervised similarity assessment, International Conference on Machine Learning and Data Mining, 2005. ,
Nonlinear Dimensionality Reduction by Locally Linear Embedding, Science, vol.290, issue.5500, 2000. ,
DOI : 10.1126/science.290.5500.2323
The cmu motion of body (mobo) database, 2001. ,
Information and the Accuracy Attainable in the Estimation of Statistical Parameters, Bull. Calcutta Math. Soc, vol.37, pp.81-91, 1945. ,
DOI : 10.1007/978-1-4612-0919-5_16
Differential Geometry of Curved Exponential Families-Curvatures and Information Loss, The Annals of Statistics, vol.10, issue.2, pp.357-87, 1982. ,
DOI : 10.1214/aos/1176345779
Differential geometric methods in statistics, 1985. ,
The gap metric: Robustness of stabilization of feedback systems, IEEE Transactions on Automatic Control, vol.30, issue.3, pp.240-247, 1985. ,
DOI : 10.1109/TAC.1985.1103926
Distance metric learning with applications to clustering with side information, Advances in Neural Information Processing Systems, p.3, 2003. ,
Out-of-sample extensions for LLE, Isomap, MDS, eigenmaps, and spectral clustering, 2003. ,
Adjustment Learning and Relevant Component Analysis, p.2, 2002. ,
DOI : 10.1007/3-540-47979-1_52
Computing the volume element of a family of metrics on the multinomial simplex, 2003. ,
Differential Geometry and Statistics, 1993. ,
Semi-Supervised Learning on Riemannian Manifolds, Machine Learning, vol.56, issue.1-3, 2004. ,
DOI : 10.1023/B:MACH.0000033120.25363.1e
Theory of Probability, 1983. ,
Riemannian Geometry, Berlin), vol.3, p.5 ,
Aspects of Fisher geometry for stochastic linear systems, problem 25, Open Problems in Mathematical Systems and Control Theory, pp.2002-2029, 2002. ,
System identification based on Riemannian geometry, Tinbergen Inst. Res. Ser, vol.3, 1994. ,
Symbolic computation of Fisher information matrices for parametrized state-space systems, Automatica, vol.35, issue.6, pp.1059-1071, 1999. ,
DOI : 10.1016/S0005-1098(99)00004-7
Differential geometric models for time-varying coefficients of autoregressive processes, p.5, 1994. ,
ON THE RIEMANNIAN MANIFOLD STRUCTURE OF CLASSES OF LINEAR SYSTEMS, EQUADIFF 2003, 2003. ,
DOI : 10.1142/9789812702067_0096
DIFFERENTIAL GEOMETRY OF ARMA MODELS, Journal of Time Series Analysis, vol.46, issue.3, pp.259-274, 1990. ,
DOI : 10.1016/0047-259X(86)90055-2
Fisher optimal approximation of an AR(n)-process by an AR(n-1)-process, Proceedings of ECC'93, pp.1225-1229, 1993. ,
Identifiability, recursive identification and spaces of linear dynamical systems, CWI Tracts, pp.63-64, 1989. ,
