Robotic mapping: A survey, Exploring Artificial Intelligence in the New Millenium, 2003. ,
Position referencing and consistent world modeling for mobile robots, Proceedings. 1985 IEEE International Conference on Robotics and Automation, 1985. ,
DOI : 10.1109/ROBOT.1985.1087373
SLAM using Incremental Probabilistic PCA and Dimensionality Reduction, Proceedings of the 2005 IEEE International Conference on Robotics and Automation, 2005. ,
DOI : 10.1109/ROBOT.2005.1570142
Error correction in mobile robot map learning, Proceedings 1992 IEEE International Conference on Robotics and Automation, 1992. ,
DOI : 10.1109/ROBOT.1992.220057
Performance of a distributed robotic system using shared communications channels, IEEE T ROBOTIC AUTOM, vol.22, issue.5, pp.713-727, 2002. ,
Using visual features to build topological maps of indoor environments, 2003 IEEE International Conference on Robotics and Automation (Cat. No.03CH37422), 2003. ,
DOI : 10.1109/ROBOT.2003.1241699
Object recognition by computer: the role of geometric constraints, 1990. ,
Collaborative exploration of unknown environments with teams of mobile robots, " in Advances in Plan-Based Control of Robotic Agents, pp.52-70, 2002. ,
A practical, decisiontheoretic approach to multi-robot mapping and exploration, Proc. of the IEEE/RSJ Int'l Conf. on Intelligent Robots and Systems, pp.3232-3238, 2003. ,
Cooperative concurrent mapping and localization, Proceedings 2002 IEEE International Conference on Robotics and Automation (Cat. No.02CH37292), pp.1810-1817, 2002. ,
DOI : 10.1109/ROBOT.2002.1014804
Measurement and correction of systematic odometry errors in mobile robots, IEEE Transactions on Robotics and Automation, vol.12, issue.6, pp.869-880, 1996. ,
DOI : 10.1109/70.544770
A solution to the simultaneous localization and map building (SLAM) problem, IEEE Transactions on Robotics and Automation, vol.17, issue.3, pp.229-241, 2001. ,
DOI : 10.1109/70.938381
Optimization of the simultaneous localization and map-building algorithm for real-time implementation, IEEE Transactions on Robotics and Automation, vol.17, issue.3, pp.242-257, 2001. ,
DOI : 10.1109/70.938382
Coordination for multi-robot exploration and mapping, Proc. of the Nat'l Conf. on Artificial Intelligence, pp.852-858, 2000. ,
A probabilistic approach to concurrent mapping and localization for mobile robots, MACH LEARN and AUTON ROBOT, vol.31, issue.5, pp.1-25, 1998. ,
A probabilistic online mapping algorithm for teams of mobile robots, INT J ROBOT RES, 2001. ,
FastSLAM: An efficient solution to the simultaneous localization and mapping problem with unknown data association, Journal of Machine Learning Research, 2004. ,
Multi-robot mapping using manifold representations, IEEE International Conference on Robotics and Automation, 2004. Proceedings. ICRA '04. 2004, pp.4198-4203, 2004. ,
DOI : 10.1109/ROBOT.2004.1308933
Multi-robot collaboration for robust exploration, Proceedings 2000 ICRA. Millennium Conference. IEEE International Conference on Robotics and Automation. Symposia Proceedings (Cat. No.00CH37065), pp.7-40, 2001. ,
DOI : 10.1109/ROBOT.2000.845150
A highly efficient fast- SLAM algorithm for generating cyclic maps of large-scale environments from raw laser range measurements, Proc. of the IEEE/RSJ Int'l Conf. on Intelligent Robots and Systems, 2003. ,
Sensor Fusion in Certainty Grids for Mobile Robots, AI Magazine, vol.9, issue.2, pp.61-74, 1988. ,
DOI : 10.1007/978-3-642-74567-6_19
Rao- Blackwellized particle filtering for dynamic Bayesian networks, Proc. Conf. on Uncertainty in Artificial Intelligence, 2000. ,
Map merging for distributed robot navigation, Proceedings 2003 IEEE/RSJ International Conference on Intelligent Robots and Systems (IROS 2003) (Cat. No.03CH37453), 2003. ,
DOI : 10.1109/IROS.2003.1250630
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.118.2868
Incremental mapping of large cyclic environments, Proceedings 1999 IEEE International Symposium on Computational Intelligence in Robotics and Automation. CIRA'99 (Cat. No.99EX375), 1999. ,
DOI : 10.1109/CIRA.1999.810068
Gloablly consistent range scan alignment for environment mapping, Autonomous Robots, vol.4, issue.4, pp.333-349, 1997. ,
DOI : 10.1023/A:1008854305733
Blanche-an experiment in guidance and navigation of an autonomous robot vehicle, IEEE Transactions on Robotics and Automation, vol.7, issue.2, pp.193-204, 1991. ,
DOI : 10.1109/70.75902
AMOS: comparison of scan matching approaches for self-localization in indoor environments, Proceedings of the First Euromicro Workshop on Advanced Mobile Robots (EUROBOT '96), pp.61-67, 1996. ,
DOI : 10.1109/EURBOT.1996.551882
Keeping track of position and orientation of moving indoor systems by correlation of range-finder scans, Proceedings of IEEE/RSJ International Conference on Intelligent Robots and Systems (IROS'94), pp.12-16, 1994. ,
DOI : 10.1109/IROS.1994.407420
Building consistent laser scan map, Proc. of the European Workshop On Advanced Mobile Robots, pp.83-90, 2001. ,
Line segment based map building and localization using 2D laser rangefinder, Proceedings 2000 ICRA. Millennium Conference. IEEE International Conference on Robotics and Automation. Symposia Proceedings (Cat. No.00CH37065), pp.2538-2543, 2000. ,
DOI : 10.1109/ROBOT.2000.846410
Robot motion planning for map building, IEEE/RSJ International Conference on Intelligent Robots and System, pp.673-680, 2002. ,
DOI : 10.1109/IRDS.2002.1041469
Localizing while mapping: A segment approach, Proc. of the Eighteen Nat'l Conf. on Artificial Intelligence, pp.959-960, 2002. ,
Real-time self-localization in unknown indoor environment using a panorama laser range finder, Proceedings of the 1997 IEEE/RSJ International Conference on Intelligent Robot and Systems. Innovative Robotics for Real-World Applications. IROS '97, pp.697-702, 1997. ,
DOI : 10.1109/IROS.1997.655087
Building polygonal maps from laser range data, Int'l Cognitive Robotics Workshop, 2004. ,
A scan matching method using Euclidean invariant signature for global localization and map building, IEEE International Conference on Robotics and Automation, 2004. Proceedings. ICRA '04. 2004, pp.866-871, 2004. ,
DOI : 10.1109/ROBOT.2004.1307258
Scan matching based on CLS relationships, IEEE International Conference on Robotics, Intelligent Systems and Signal Processing, 2003. Proceedings. 2003, 2003. ,
DOI : 10.1109/RISSP.2003.1285556
Navigation Strategies for Exploring Indoor Environments, The International Journal of Robotics Research, vol.20, issue.5, pp.829-848, 2002. ,
DOI : 10.1177/0278364902021010834
A local map building process for a reactive navigation of a mobile robot, IEEE International Conference on Robotics and Automation, 2004. Proceedings. ICRA '04. 2004, 2004. ,
DOI : 10.1109/ROBOT.2004.1302484
URL : https://hal.archives-ouvertes.fr/hal-00920627
Scan matching without odometry information, Proc. of the IEEE Int'l Conf. on Robotics and Automation, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-00817540
The robotics data set repository (radish), 2003. ,
