K. S. Arun, T. S. Huang, and S. D. Blostein, Least-Squares Fitting of Two 3-D Point Sets, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.9, issue.5, pp.9698-700, 1987.
DOI : 10.1109/TPAMI.1987.4767965
M. Belkin and P. Niyogi, Laplacian eigenmaps and spectral techniques for embedding and clustering, 2002.
C. Bishop, Pattern Recognition and Machine Learning, 2006.
T. Caelli and S. Kosinov, An eigenspace projection clustering method for inexact graph matching. Pattern Analysis and Machine Intelligence PAMI, 2004.
M. Carcassoni and E. R. Hancock, Correspondence matching with modal clusters. Pattern Analysis and Machine Intelligence PAMI, pp.1609-1615, 2003.
M. Carcassoni and E. R. Hancock, Spectral correspondence for point pattern matching, Pattern Recognition, vol.36, issue.1, pp.193-204, 2003.
DOI : 10.1016/S0031-3203(02)00054-7
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.146.1779
F. Chang, Spectral Graph Theory, 1997.
DOI : 10.1090/cbms/092
H. Chui and A. Rangarajan, A new point matching algorithm for non-rigid registration, Computer Vision and Image Understanding, vol.89, issue.2-3, pp.114-141, 2003.
DOI : 10.1016/S1077-3142(03)00009-2
A. Cross and E. Hancock, Graph matching with a dual-step EM algorithm, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.20, issue.11, pp.1236-1253, 1998.
DOI : 10.1109/34.730557
G. Dewaele, F. Devernay, R. Horaud, and F. Forbes, The Alignment Between 3-D Data and Articulated Shapes with Bending Surfaces, Proceedings of the 9th European Conference on Computer Vision volume III of LNCS, pp.578-591, 2006.
DOI : 10.1007/11744078_45
URL : https://hal.archives-ouvertes.fr/inria-00262288
A. Elad and R. Kimmel, On bending invariant signatures for surfaces. Pattern Analysis and Machine Intelligence PAMI, pp.1285-1295, 2003.
S. Gold and A. Rangarajan, A graduated assignment algorithm for graph matching, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.18, issue.4, pp.377-388, 1996.
DOI : 10.1109/34.491619
S. Granger and X. Pennec, Multi-scale EM-ICP: A Fast and Robust Approach for Surface Registration, ECCV02, p.418, 2002.
DOI : 10.1007/3-540-47979-1_28
URL : https://hal.archives-ouvertes.fr/inria-00615911
R. Horaud and H. Sossa, Polyhedral object recognition by indexing, Pattern Recognition, vol.28, issue.12, pp.1855-1870, 1995.
DOI : 10.1016/0031-3203(95)00048-8
URL : https://hal.archives-ouvertes.fr/inria-00590043
V. Jain and H. Zhang, Robust 3-d shape correspondence in the spectral domain, IEEE International Conference on Shape Modeling and Applications16] B. Luo and E. Hancock. A unified framework for alignment and correspondence. CVIU, pp.26-55, 2003.
J. Mejia, T. Villela, and J. Braga, The CCD stellar sensor of the MASCO telescope pointing system, Advances in Space Research, vol.26, issue.9, pp.1407-1410, 2000.
DOI : 10.1016/S0273-1177(00)00069-7
M. Niethammer, M. Reuter, F. Wolter, N. P. Bouix, M. Koo et al., Global Medical Shape Analysis Using the Laplace-Beltrami Spectrum, MICCAI07, 10th International Converence on Medical Image Computing and Computer Assisted Intervention, 2007.
DOI : 10.1007/978-3-540-75757-3_103
S. Roweis and L. Saul, Nonlinear Dimensionality Reduction by Locally Linear Embedding, Science, vol.290, issue.5500, pp.2323-2326, 2000.
DOI : 10.1126/science.290.5500.2323
URL : http://astro.temple.edu/~msobel/courses_files/saulmds.pdf
G. Scott and C. L. Higgins, An Algorithm for Associating the Features of Two Images, Biological Sciencces, pp.21-26, 1991.
DOI : 10.1098/rspb.1991.0045
L. Shapiro and J. M. Brady, Feature-based correspondence: an eigenvector approach, Image and Vision Computing, pp.283-288, 1992.
DOI : 10.1016/0262-8856(92)90043-3
W. Taylor, Protein Structure Comparison Using Bipartite Graph Matching and Its Application to Protein Structure Classification, Molecular & Cellular Proteomics, vol.1, issue.4, pp.334-340, 2002.
DOI : 10.1074/mcp.T200001-MCP200
J. Tenenbaum, V. De-silva, and J. Jangford, A Global Geometric Framework for Nonlinear Dimensionality Reduction, Science, vol.290, issue.5500, pp.2319-2323, 2000.
DOI : 10.1126/science.290.5500.2319
S. Umeyama, An eigendecomposition approach to weighted graph matching problems, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.10, issue.5, pp.695-703, 1988.
DOI : 10.1109/34.6778
S. Umeyama, Least-squares estimation of transformation parameters between two point patterns, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.13, issue.4, pp.376-380, 1991.
DOI : 10.1109/34.88573
W. Wells and I. , Statistical approaches to feature-based object recognition, International Journal of Computer Vision, vol.28, issue.12, pp.63-98, 1997.
Z. Zhang, Iterative point matching for registration of free-form curves and surfaces, International Journal of Computer Vision, vol.7, issue.3, pp.119-152, 1994.
DOI : 10.1007/BF01427149
