Multihomogeneous polynomial decomposition using moment matrices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2011
In the paper, we address the important problem of tensor decomposition which can be seen as a generalisation of Singular Value Decomposition for matrices. We consider general multilinear and multihomogeneous tensors. We show how to reduce the problem to a truncated moment matrix problem and give a new criterion for flat extension of Quasi-Hankel matrices. We connect this criterion to the commutation characterisation of border bases. A new algorithm is described. It applies for general multihomogeneous tensors, extending the approach of J.J. Sylvester on binary forms. An example illustrates the algebraic operations involved in this approach and how the decomposition can be recovered from eigenvector computation.
paper.pdf (321.23 Ko) Télécharger le fichier
inria-00590965 , version 1 (05-05-2011)
inria-00590965 , version 2 (20-05-2011)
inria-00590965 , version 3 (20-10-2011)
  • HAL Id : inria-00590965 , version 2
  • ARXIV : 1105.1229
Alessandra Bernardi, Jerome Brachat, Pierre Comon, Bernard Mourrain. Multihomogeneous polynomial decomposition using moment matrices. 2011, pp.35-42. ⟨inria-00590965v2⟩
605 Consultations
833 Téléchargements
