Expressing Polymorphic Types in a Many-Sorted Language - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
In this paper, we study translation from a first-order logic with polymorphic types à la ML (of which we give a formal description) to a many-sorted or one-sorted logic as accepted by the mainstream automated theorem provers. We consider a three-stage scheme where the last stage eliminates polymorphic types while adding the necessary "annotations" to preserve soundness, and the first two stages serve to protect certain terms so that they can keep their original unannotated form. This protection allows us to make use of provers' built-in theories and operations. We present two existing translation procedures as sound and complete instances of this generic scheme. Our formulation generalizes over the previous ones by allowing to protect terms of arbitrary monomorphic types. In particular, we can benefit from the built-in theory of arrays in SMT solvers such as Z3 and CVC3. The proposed methods are implemented in the Why3 tool and we compare their performance in combination with several automated provers.
polyfol.pdf (314.85 Ko) Télécharger le fichier
inria-00591414 , version 1 (09-05-2011)
inria-00591414 , version 2 (09-05-2011)
inria-00591414 , version 3 (11-07-2011)
inria-00591414 , version 4 (26-07-2011)
  • HAL Id : inria-00591414 , version 1
François Bobot, Andrei Paskevich. Expressing Polymorphic Types in a Many-Sorted Language. [Research Report] 2011. ⟨inria-00591414v1⟩
286 Consultations
327 Téléchargements
