New interface
Journal articles
Tradeoffs in process strategy games with application in the WDM reconfiguration problem
Nathann Cohen 1 David Coudert 1 Dorian Mazauric 1 Napoleao Nepomuceno 1, 2 Nicolas Nisse 1
1 MASCOTTE - Algorithms, simulation, combinatorics and optimization for telecommunications
CRISAM - Inria Sophia Antipolis - Méditerranée , Laboratoire I3S - COMRED - COMmunications, Réseaux, systèmes Embarqués et Distribués
Abstract : We consider a variant of the graph searching games that models the routing reconfiguration problem in WDM networks. In the digraph processing game, a team of agents aims at processing, or clearing, the vertices of a digraph D. We are interested in two different measures: 1) the total number of agents used, and 2) the total number of vertices occupied by an agent during the processing of D. These measures respectively correspond to the maximum number of simultaneous connections interrupted and to the total number of interruptions during a routing reconfiguration in a WDM network. Previous works have studied the problem of independently minimizing each of these parameters. In particular, the corresponding minimization problems are APX-hard, and the first one is known not to be in APX. In this paper, we give several complexity results and study tradeoffs between these conflicting objectives. In particular, we show that minimizing one of these parameters while the other is constrained is NP-complete. Then, we prove that there exist some digraphs for which minimizing one of these objectives arbitrarily impairs the quality of the solution for the other one. We show that such bad tradeoffs may happen even for a basic class of digraphs. On the other hand, we exhibit classes of graphs for which good tradeoffs can be achieved. We finally detail the relationship between this game and the routing reconfiguration problem. In particular, we prove that any instance of the processing game, i.e. any digraph, corresponds to an instance of the routing reconfiguration problem.
Document type :
Journal articles
Complete list of metadata
Cited literature [21 references]  Display  Hide  Download
https://hal.inria.fr/inria-00592507
Contributor : Dorian Mazauric Connect in order to contact the contributor
Submitted on : Thursday, May 12, 2011 - 4:56:38 PM
Last modification on : Thursday, August 4, 2022 - 4:52:43 PM
Long-term archiving on: : Friday, November 9, 2012 - 11:15:58 AM
File
paper-noformat.pdf
Identifiers
Collections
Citation
Nathann Cohen, David Coudert, Dorian Mazauric, Napoleao Nepomuceno, Nicolas Nisse. Tradeoffs in process strategy games with application in the WDM reconfiguration problem. Theoretical Computer Science, 2011, 412 (35), pp.4675-4687. ⟨10.1016/j.tcs.2011.05.002⟩. ⟨inria-00592507⟩
Share
Metrics
Record views
175
Files downloads
180
