The Carbon Assimilation Network in Escherichia coli Is Densely Connected and Largely Sign-Determined by Directions of Metabolic Fluxes, PLoS Computational Biology, vol.11, issue.6, p.1000812, 2010. ,
DOI : 10.1371/journal.pcbi.1000812.s003
URL : https://hal.archives-ouvertes.fr/hal-00793021
Symbolic reachability analysis of genetic regulatory networks using discrete abstractions, Automatica, vol.44, issue.4, pp.982-989, 2008. ,
DOI : 10.1016/j.automatica.2007.08.004
URL : https://hal.archives-ouvertes.fr/hal-00319485
Efficient parameter search for qualitative models of regulatory networks using symbolic model checking, Bioinformatics, vol.26, issue.18, pp.26-603, 2010. ,
DOI : 10.1093/bioinformatics/btq387
URL : https://hal.archives-ouvertes.fr/inria-00482569
Computational Modeling of Gene Regulatory Networks ? A Primer, 2008. ,
DOI : 10.1142/p567
Gene networks: how to put the function in genomics, Trends in Biotechnology, vol.20, issue.11, pp.467-472, 2002. ,
DOI : 10.1016/S0167-7799(02)02053-X
Dynamic modeling of the central carbon metabolism ofEscherichia coli, Biotechnology and Bioengineering, vol.81, issue.1, pp.53-73, 2002. ,
DOI : 10.1002/bit.10288
Methods of robustness analysis for Boolean models of gene control networks, IEE Proceedings - Systems Biology, vol.153, issue.4, pp.154-167, 2006. ,
DOI : 10.1049/ip-syb:20050079
Integrating high-throughput and computational data elucidates bacterial networks, Nature, vol.429, issue.6987, pp.42992-100, 2004. ,
DOI : 10.1038/nature02456
Integrating metabolic, transcriptional regulatory and signal transduction models in Escherichia coli, Bioinformatics, vol.24, issue.18, pp.2044-2050, 2008. ,
DOI : 10.1093/bioinformatics/btn352
The transition from differential equations to Boolean networks: A case study in simplifying a regulatory network model, Journal of Theoretical Biology, vol.255, issue.3, 2008. ,
DOI : 10.1016/j.jtbi.2008.07.020
Modeling and Simulation of Genetic Regulatory Systems: A Literature Review, Journal of Computational Biology, vol.9, issue.1, pp.67-103, 2002. ,
DOI : 10.1089/10665270252833208
Qualitative simulation of the initiation of sporulation in, Bulletin of Mathematical Biology, vol.66, issue.2, pp.261-299, 2004. ,
DOI : 10.1016/j.bulm.2003.08.009
URL : https://hal.archives-ouvertes.fr/inria-00072061
Genetic Network Analyzer: qualitative simulation of genetic regulatory networks, Bioinformatics, vol.19, issue.3, pp.336-344, 2003. ,
DOI : 10.1093/bioinformatics/btf851
URL : https://hal.archives-ouvertes.fr/inria-00072325
Qualitative simulation of genetic regulatory networks using piecewise-linear models, Bulletin of Mathematical Biology, vol.66, issue.2, pp.301-340, 2004. ,
DOI : 10.1016/j.bulm.2003.08.010
URL : https://hal.archives-ouvertes.fr/hal-00173849
Search for Steady States of Piecewise-Linear Differential Equation Models of Genetic Regulatory Networks, IEEE/ACM Transactions on Computational Biology and Bioinformatics, vol.5, issue.2, pp.208-222, 2008. ,
DOI : 10.1109/TCBB.2007.70254
URL : https://hal.archives-ouvertes.fr/hal-01178204
Strategies for dealing with incomplete information in the modeling of molecular interaction networks, Briefings in Bioinformatics, vol.7, issue.4, pp.354-363, 2006. ,
DOI : 10.1093/bib/bbl034
Logical modelling of cell cycle control in eukaryotes: a comparative study, Molecular BioSystems, vol.7, issue.12, pp.1569-1581, 2009. ,
DOI : 10.1038/msb4100126
The logical analysis of continuous, non-linear biochemical control networks, Journal of Theoretical Biology, vol.39, issue.1, pp.103-129, 1973. ,
DOI : 10.1016/0022-5193(73)90208-7
Identification of regulatory network topological units coordinating the genome-wide transcriptional response to glucose in Escherichia coli, BMC Microbiology, vol.7, issue.1, p.53, 2007. ,
DOI : 10.1186/1471-2180-7-53
Topology of the global regulatory network of carbon limitation in Escherichia coli, Journal of Biotechnology, vol.132, issue.4, pp.359-374, 2007. ,
DOI : 10.1016/j.jbiotec.2007.08.029
The Regulation of Cellular Systems, 1996. ,
DOI : 10.1007/978-1-4613-1161-4
A lowered concentration of cAMP receptor protein caused by glucose is an important determinant for catabolite repression in Escherichia coli, Molecular Microbiology, vol.136, issue.2, p.341350, 1993. ,
DOI : 10.1111/j.1365-2958.1993.tb01960.x
A Global Regulatory Role of Gluconeogenic Genes in Escherichia coli Revealed by Transcriptome Network Analysis, Journal of Biological Chemistry, vol.280, issue.43, pp.28036079-36087, 2005. ,
DOI : 10.1074/jbc.M508202200
Dynamics in high-dimensional model gene networks, Signal Processing, vol.83, issue.4, pp.789-798, 2003. ,
DOI : 10.1016/S0165-1684(02)00479-6
Modelling and analysis of gene regulatory networks, Nature Reviews Molecular Cell Biology, vol.18, issue.10, pp.770-780, 2008. ,
DOI : 10.1038/nrm2503
EcoCyc: A comprehensive view of Escherichia coli biology, Nucleic Acids Research, vol.37, issue.Database, pp.464-470, 2009. ,
DOI : 10.1093/nar/gkn751
Nonlinear Systems, 2001. ,
Integrative model of the response of yeast to osmotic shock, Nature Biotechnology, vol.53, issue.8, pp.975-982, 2005. ,
DOI : 10.1016/0006-3002(58)90330-5
Bacterial adaptation through distributed sensing of metabolic fluxes, Molecular Systems Biology, vol.73, p.355, 2010. ,
DOI : 10.1016/S1369-5274(03)00033-X
Comment on mathematical models which describe transcription and calculate the relationship between mRNA and protein expression ratio, Biotechnology and Bioengineering, vol.84, issue.4, pp.815-819, 2007. ,
DOI : 10.1002/bit.21065
Global Transcriptional Programs Reveal a Carbon Source Foraging Strategy by Escherichia coli, Journal of Biological Chemistry, vol.280, issue.16, pp.28015921-15927, 2005. ,
DOI : 10.1074/jbc.M414050200
Starvation for Different Nutrients in Escherichia coli Results in Differential Modulation of RpoS Levels and Stability, Journal of Bacteriology, vol.187, issue.2, 2005. ,
DOI : 10.1128/JB.187.2.434-442.2005
Temporal logic patterns for querying dynamic models of cellular interaction networks, Bioinformatics, vol.24, issue.16, pp.24-227, 2008. ,
DOI : 10.1093/bioinformatics/btn275
URL : https://hal.archives-ouvertes.fr/inria-00357805
Logicbased models for the analysis of cell signaling networks, Biochemistry, issue.15, pp.493216-3225, 2010. ,
Cyclic AMP-Dependent Catabolite Repression Is the Dominant Control Mechanism of Metabolic Fluxes under Glucose Limitation in Escherichia coli, Journal of Bacteriology, vol.190, issue.7, pp.2323-2330, 2008. ,
DOI : 10.1128/JB.01353-07
Global Expression Profiling of Acetate-grown Escherichia coli, Journal of Biological Chemistry, vol.277, issue.15, pp.27713175-13183, 2002. ,
DOI : 10.1074/jbc.M110809200
Global metabolic regulation analysis for Escherichia coli K12 based on protein expression by 2-dimensional electrophoresis and enzyme activity measurement, Applied Microbiology and Biotechnology, vol.93, issue.2, pp.61163-178, 2003. ,
DOI : 10.1007/s00253-002-1202-6
A methodological basis for description and analysis of systems with complex switch-like interactions, Journal of Mathematical Biology, vol.36, issue.4, pp.321-348, 1998. ,
DOI : 10.1007/s002850050103
Comparing different ODE modelling approaches for gene regulatory networks, Journal of Theoretical Biology, vol.261, issue.4, pp.511-541, 2009. ,
DOI : 10.1016/j.jtbi.2009.07.040
URL : https://hal.archives-ouvertes.fr/hal-00554639
Metabolic control theory: A structural approach, Journal of Theoretical Biology, vol.135, issue.2, pp.175-201, 1988. ,
DOI : 10.1016/S0022-5193(88)80073-0
Model Reduction Using Piecewise-Linear Approximations Preserves Dynamic Properties of the Carbon Starvation Response in Escherichia coli, IEEE/ACM Transactions on Computational Biology and Bioinformatics, vol.8, issue.1, pp.166-181, 2011. ,
DOI : 10.1109/TCBB.2009.49
URL : https://hal.archives-ouvertes.fr/hal-00793034
Qualitative simulation of the carbon starvation response in Escherichia coli, Biosystems, vol.84, issue.2, pp.124-152, 2006. ,
DOI : 10.1016/j.biosystems.2005.10.005
URL : https://hal.archives-ouvertes.fr/hal-00171698
Regulation of carbon utilization, Escherichia coli and Salmonella: Cellular and Molecular Biology, pp.1325-1368, 1996. ,
Effect of cra gene knockout together with edd and iclR genes knockout on the metabolism in Escherichia coli, Archives of Microbiology, vol.68, issue.3, pp.558-571, 2008. ,
DOI : 10.1007/s00203-008-0406-2
Modeling the onset of virulence in a pectinolytic bacterium, Journal of Theoretical Biology, vol.244, issue.2, pp.239-257, 2007. ,
DOI : 10.1016/j.jtbi.2006.08.010
URL : https://hal.archives-ouvertes.fr/hal-00138078
A genome-scale computational study of the interplay between transcriptional regulation and metabolism, Molecular Systems Biology, vol.102, p.101, 2007. ,
DOI : 10.1038/msb4100141
Qualitative dynamics of piecewise-linear differential equations: a discrete mapping approach, Dynamics and Stability of Systems, vol.54, issue.3-4, pp.3-4189, 1989. ,
DOI : 10.1016/S0006-3495(71)86192-1
P1 promoter depends on a complex combination of functional determinants, Biochemical Journal, vol.383, issue.2, pp.371-382, 2004. ,
DOI : 10.1042/BJ20040792
Modeling the Quorum Sensing Regulatory Network of Human-Pathogenic Pseudomonas aeruginosa, Biotechnology Progress, vol.20, issue.3, pp.670-678, 2004. ,
DOI : 10.1021/bp034323l
Control of rpoS transcription in Escherichia coli and Pseudomonas: why so different?, Molecular Microbiology, vol.273, issue.1, pp.1-9, 2003. ,
DOI : 10.1046/j.1365-2958.2003.03547.x
Transforming Boolean models to continuous models: methodology and application to T-cell receptor signaling, BMC Systems Biology, vol.3, issue.1, p.98, 2009. ,
DOI : 10.1186/1752-0509-3-98
URL : http://doi.org/10.1186/1752-0509-3-98
level in starving Escherichia coli cells increases solely as a result of its increased stability, despite decreased synthesis, Molecular Microbiology, vol.24, issue.3, pp.643-652, 1997. ,
DOI : 10.1046/j.1365-2958.1997.3961742.x
