Edge noise in document images, Proceedings of The Third Workshop on Analytics for Noisy Unstructured Text Data, AND '09, pp.17-24, 2009. ,
DOI : 10.1145/1568296.1568302
An efficient algorithm for smoothing, linearization and detection of structural feature points of binary image contours, Pattern Recognition, vol.30, issue.1, pp.57-69, 1997. ,
DOI : 10.1016/S0031-3203(96)00055-6
Image and document processing techniques for the RightPages electronic library system, Proc. of the 11th Int. Conf. on Pattern Recognition, pp.260-263, 1992. ,
Modeling image degradations for improving OCR, Proceedings of the 16th European Signal Processing Conference, 2008. ,
singularities, Communications on Pure and Applied Mathematics, vol.9, issue.7, pp.219-266, 2002. ,
DOI : 10.1002/cpa.10116
Atomic Decomposition by Basis Pursuit, SIAM Journal on Scientific Computing, vol.20, issue.1, pp.33-61, 1998. ,
DOI : 10.1137/S1064827596304010
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.113.7694
Adaptive greedy approximations, Constructive Approximation, vol.21, issue.1, pp.57-98, 1997. ,
DOI : 10.1007/BF02678430
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.47.7530
For most large underdetermined systems of linear equations the minimal ???1-norm solution is also the sparsest solution, Communications on Pure and Applied Mathematics, vol.50, issue.6, pp.797-829, 2004. ,
DOI : 10.1002/cpa.20132
Sparse and Redundant Representations: From Theory to Applications in Signal and Image Processing, 2010. ,
DOI : 10.1007/978-1-4419-7011-4
Report on the second symbol recognition contest Available at, LNCS, vol.3926, pp.381-397, 2005. ,
