New interface
Conference papers
Optimisation convexe pour l'estimation simultanée de réponses acoustiques
Alexis Benichoux 1 Emmanuel Vincent 1 Rémi Gribonval 1
1 METISS - Speech and sound data modeling and processing
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, Inria Rennes – Bretagne Atlantique
Abstract : We consider the estimation of acoustic impulse responses from the simultaneous recording of several known sources. Existing techniques are restricted to the case where the number of sources is at most equal to the number of sensors. We relax this assumption in the case where the sources are known. To this aim, we propose statistical models of the filters associated with a convex log-likelihood, and we propose a convex optimization algorithm to solve the inverse problem, with the resulting penalties. We provide a comparaison between penalties via a set of experiments which shows that the proposed method allows to obtain a robust estimation, and greatly improves performance compared to the naive approach.
Complete list of metadata
Cited literature [11 references]  Display  Hide  Download
https://hal.inria.fr/inria-00594252
Contributor : Alexis Benichoux Connect in order to contact the contributor
Submitted on : Thursday, May 19, 2011 - 3:22:50 PM
Last modification on : Friday, May 6, 2022 - 4:26:01 PM
Long-term archiving on: : Saturday, December 3, 2016 - 3:50:01 PM
Identifiers
  • HAL Id : inria-00594252, version 2
Citation
Alexis Benichoux, Emmanuel Vincent, Rémi Gribonval. Optimisation convexe pour l'estimation simultanée de réponses acoustiques. 23e Colloque du Groupement de Recherche en Traitement du Signal et des Images, Sep 2011, Bordeaux, France. ⟨inria-00594252v2⟩
Share
Metrics
Record views
223
Files downloads
261
